  1. Last week
  2. flint_perch286
    Louver position on the hood
    The factory hood measurements above should get you close, but lining them up with the inner hood crease matters more than just squaring them off the outer edge.
  3. bluecalais79
    Front Dash Speakers
  4. rich_e777
    Front Dash Speakers
  5. bluecalais79
    Front Dash Speakers
  6. Earlier
  7. 94 olds vert
    Front Dash Speakers
  8. bluecalais79
    Front Dash Speakers
  9. SuperBuick
  10. Amanita
    Rough idle/ volt drop
  11. Jscott
  12. rich_e777
    Digi UB3 adapter
  13. 55trucker
    4T65E Range Selector Bracket
  14. phewop118
  15. 94 olds vert
    Digi UB3 adapter
    This thread is 15 years old.
  16. rich_e777
    Digi UB3 adapter
  17. The LQ1 timing stuff looks intimidating until it's laid out step by step. That video saves a lot of random forum digging.
  18. hazelspindle3
    New member with 98 lumina
  19. hazelspindle3
  20. calmspindle6
    New to this place. Hello.
  21. That video is one of those rabbit holes where you start with a tensioner and end up learning the whole LQ1 timing setup. Pretty handy to have around.
  22. covefinch9
  23. A reman label really muddies the water, so the broadcast code is the one piece that settles it. A logger that connects with the wrong stream can look believable right up until it sends you chasing nonsense.
  24. Those convertible-specific seals and interior bits can be a real scavenger hunt, but an 80k car that's been garaged is a solid starting point. Getting him one more ride in it would be pretty special.
  25. mossyelk
  26. briskshovel88
  27. pwmin
