  1. Earlier
  2. bluecalais79
    Front Dash Speakers
  3. rich_e777
    Front Dash Speakers
  4. bluecalais79
    Front Dash Speakers
  5. 94 olds vert
    Front Dash Speakers
  6. bluecalais79
    Front Dash Speakers
  7. SuperBuick
    Louver position on the hood
  8. Amanita
    Rough idle/ volt drop
  9. Jscott
  10. rich_e777
    Digi UB3 adapter
  11. 55trucker
    4T65E Range Selector Bracket
  12. phewop118
  13. 94 olds vert
    Digi UB3 adapter
    This thread is 15 years old.
  14. rich_e777
    Digi UB3 adapter
  15. The LQ1 timing stuff looks intimidating until it's laid out step by step. That video saves a lot of random forum digging.
  16. hazelspindle3
    New member with 98 lumina
  17. hazelspindle3
  18. calmspindle6
    New to this place. Hello.
  19. That video is one of those rabbit holes where you start with a tensioner and end up learning the whole LQ1 timing setup. Pretty handy to have around.
  20. covefinch9
  21. A reman label really muddies the water, so the broadcast code is the one piece that settles it. A logger that connects with the wrong stream can look believable right up until it sends you chasing nonsense.
  22. Those convertible-specific seals and interior bits can be a real scavenger hunt, but an 80k car that's been garaged is a solid starting point. Getting him one more ride in it would be pretty special.
  23. mossyelk
  24. briskshovel88
  25. pwmin
  26. Kdog
    charm.li free forever
