  1. Yesterday
  2. I’m hoping that somebody still sees this string because I’ve been reading it and it is very interesting for my problem. I have a 93 convertible and after getting it out of winter storage a couple weeks ago I finally had an opportunity to put the top down and take it for a drive. Though I hear a slight clicking sound that seems to be coming from back by the pump, the top does not go up or down, and the pump doesn’t seem to engage at all. Besides this string of ideas, very little information is available for me to find. I looked for a fuse that would control the power to the pump and was not able to find one that looks like it is dedicated for that use. After reading this information it sounds like the relay that I was trying to find is back by the pump. I suppose that I can try testing that, but because the top doesn’t move in either direction, I’m not sure if that will be the problem. If you have any ideas, please let me know. Thanks.
  3. Last week
  4. Describe the *noise* you are hearing.......you say that this was heard when the original spring was still in place? Does the *replacement* spring still have the rubber pads glued to the ends of the leaf?
  5. The spring is installed and functional, the car a bit higher in the rear but I expected that. What I didn't expect is for the noise to return after about a day. I am wonder if it is the point where the spring contacts the plastic isolator and or where the the isolator sit in the bracket. Any ideas are appreciated.
  6. 55trucker
  7. 55trucker
  8. crazyd
  9. crazyd
  10. Schurkey
  11. 55trucker
  12. crazyd
  13. crazyd
  14. GnatGoSplat
  15. 55trucker
  16. I greased the outer tie rod and ball joint, why is it still making this noise? 20250502_104001.mp4
  17. Earlier
  18. crazyd
    '92 GTP DIC - no fuel data?
  19. crazyd
  20. Schurkey
  21. bluecalais79
  22. crazyd
  23. Schurkey
  24. I found a replacement plug for my air temp sensor on a junkyard car and am trying to get the wires out of it. I've got a round multi-tool for this that I got on Amazon that has five different tools on it but so far it looks like only the smallest straight-blade tool fits. I pushed the wires through the front of the replacement plug but that doesn't seem like the right way to do it.
  25. SuperBuick
    Bluetooth Module DIY
  26. rich_e777
  27. Black92GS
  28. SuperBuick
