The LQ1 timing stuff looks intimidating until it's laid out step by step. That video saves a lot of random forum digging. - Yesterday
hazel_trout changed their profile photo - Last week
ivan_anvil joined the community -
mossyelk joined the community -
briskshovel88 joined the community -
charm.li free forever
89 olds swaybar
Agreeing with 55 here. Those are reusable...I can send you a video of the process.
