GnatGoSplat started following '92 GTP, Why is it making this noise? , 1993 Cutlass convertible top not moving, down or up , Convertible top relays location 1995 and 1 other
I’m hoping that somebody still sees this string because I’ve been reading it and it is very interesting for my problem. I have a 93 convertible and after getting it out of winter storage a couple weeks ago I finally had an opportunity to put the top down and take it for a drive. Though I hear a slight clicking sound that seems to be coming from back by the pump, the top does not go up or down, and the pump doesn’t seem to engage at all. Besides this string of ideas, very little information is available for me to find. I looked for a fuse that would control the power to the pump and was not able to find one that looks like it is dedicated for that use. After reading this information it sounds like the relay that I was trying to find is back by the pump. I suppose that I can try testing that, but because the top doesn’t move in either direction, I’m not sure if that will be the problem. If you have any ideas, please let me know. Thanks. - Last week
Arthur joined the community
