55trucker started following hey guys! Here is my 03 monte with a 3.6 and 6t70 swap!
Megavolt-380 reacted to a post in a topic: hey guys! Here is my 03 monte with a 3.6 and 6t70 swap!
tornado_735 reacted to a post in a topic: hey guys! Here is my 03 monte with a 3.6 and 6t70 swap!
The 3.6 is quite an engine. The 6T70E seems to be a pretty-fair transmission, although it pisses me off that there's no serviceable filter. But giving up a V8 in a fairly-rare car to go backwards into ordinary? Re-think this. - Yesterday
90sEraWhips reacted to a post in a topic: 5.3L LS4 swap into a 95 Oldsmobile Cutlass Supreme SL
90sEraWhips reacted to a post in a topic: 97 cutty ls4 swap
Sonoma77 joined the community
awesome!
SSWBody joined the community
Route41 joined the community
teemancanada joined the community
Autopia joined the community
Bucksnort543 joined the community
Wow that car is awesome!
Wow this thing is beautiful!!
GnatGoSplat started following Does anyone have any vacuum harness from any 2.8 V-6 or 3.1 V6?
Dorman does sell universal hard vacuum tubing. You can probably bend it to shape with a heat gun. Years ago, I just put heatshrink tubing over the cracks. Looked like an obvious fudge-fix, but worked fine. -
90sEraWhips started following 3400
