  2. !!! A quick update for those that may still stumble on my question above. Checked the electrical all the way to the motor/pump and it’s fine. Checked the fluid level and it’s fine. Tested both relays and they are working great. I was given a suggestion to tap on the casing of the motor/pump, and that worked. The top goes up and down again. Its lift strength seems pretty wimpy so I still need to look into a possible new motor. Here’s my updated questions… Can I replace just the motor side of the motor/pump (I saw a listing on line for about $50)? If not, the only replacements that I’m seeing will cost about $350. Are there other options for replacement motor/pumps that might be a bit cheaper? Options for specifically 91-95 Cutlass replacements seem to be very limited. About motors/pumps off of a Camaro?
  3. Yesterday
  4. crazyd
  5. Last week
  6. Apparently It’s called a spring plate. If I’m seeing things correctly, it seems like it’s used to attach to lower part of a spring compressor.
  7. I dont understand what the purpose of those wings hanging off the struts are. Curious why they are/were there.
  8. I have a 93 Cutlass convertible and after getting it out of winter storage a couple weeks ago I finally had an opportunity to put the top down and take it for a drive. Though I hear a slight clicking sound that seems to be coming from back by the pump, the top does not go down or up, and the pump doesn’t seem to engage at all. It seems that very little information is available. I looked for a fuse that would control the power to the pump and was not able to find one that looks like it is dedicated for that use. A relay is a possible problem, but I am having troubles finding that. Reading what I could find on this website, it sounds like a relay or relays could be back by the pump. I can try testing that, but because the top doesn’t move in either direction, I’m not sure if that will be the problem. If you have any ideas, please let me know. Thanks.
  9. X
  10. Describe the *noise* you are hearing.......you say that this was heard when the original spring was still in place? Does the *replacement* spring still have the rubber pads glued to the ends of the leaf?
  11. The spring is installed and functional, the car a bit higher in the rear but I expected that. What I didn't expect is for the noise to return after about a day. I am wonder if it is the point where the spring contacts the plastic isolator and or where the the isolator sit in the bracket. Any ideas are appreciated.
  12. 55trucker
  13. 55trucker
  14. crazyd
  15. crazyd
  16. Schurkey
  17. 55trucker
  18. crazyd
  19. crazyd
  20. GnatGoSplat
  21. Earlier
  22. 55trucker
  23. I greased the outer tie rod and ball joint, why is it still making this noise? 20250502_104001.mp4
  24. crazyd
    '92 GTP DIC - no fuel data?
  25. crazyd
  26. Schurkey
  27. bluecalais79
  28. crazyd
  29. Schurkey
