I have the rubber right now but a critter got into my engine bay and chewed some of it off. So I am going back with the plastic tubing. I am going to use the nylon vacuum tubing. It’s flexible and it’s by Parker. Just trying to locate them. I am not sure is our lines 1/8 and the thicker line in the middle 1/4? - Last week
55trucker started following hey guys! Here is my 03 monte with a 3.6 and 6t70 swap!
Sonoma77 joined the community
awesome!
SSWBody joined the community
Route41 joined the community
teemancanada joined the community
Autopia joined the community
Bucksnort543 joined the community
Wow that car is awesome!
Wow this thing is beautiful!!
GnatGoSplat started following Does anyone have any vacuum harness from any 2.8 V-6 or 3.1 V6?
