  2. My car is currently at the mechanic after the technician repaired my main engine harness, I guess when I put my engine back together I smashed the harness behind the AC compressor bracket. Mechanic ended up bypassing To a known good 5 Volt reference after he got the same numbers that I got when I back probed my MAP, IAC and TPS. He then informed me that I had board damage on my ECM and that a 12 Volt being fed to my ECM couldn't have been good. I ended up purchasing a spare ECM. I'm preparing to head there and connect TunerPro RT V6 to my 1990 Oldsmobile Cutlass Supreme 3.1L LH0 V6, 4T60 automatic, using a GM 12-pin FTDI ALDL cable. The vehicle originally had a 16198260 ECM, and I purchased a replacement 1227727 ECM. The replacement arrived with an ARZW MEM-CAL. I'm still confirming whether my original MEM-CAL was transferred. My engine has the three-solenoid digital EGR valve. I currently have A109.adx loaded, converted from A109.ads, and corrected the Transmit Stream Reply body size from 66 to 67. I'd appreciate clarification on four questions: Is A109 the correct 8192-baud ALDL data-stream definition for the 1990 W-body LH0 with digital EGR, or should I be using the $88 acquisition definition? Has anyone successfully used A109 with the 1990 W-body 1227727 ECM and original $88-family calibration? Are there any additional ADS-to-ADX conversion settings I need to verify in TunerPro RT V6? What's the best way to confirm that the ECM is transmitting valid packets, rather than merely establishing serial communication and displaying incorrectly decoded parameters? The engine has exhibited incorrect sensor-reference voltage, rich running, injector-control problems and unreliable starting. The mechanic has repaired damaged wiring, and I'm preparing to collect a fresh KOEO/cranking XDL recording. I'm trying to verify the acquisition setup before interpreting the live readings or considering additional ECM replacement.
  3. Last week
  4. umbersparrow414
    4T65E Range Selector Bracket
  5. Earlier
  6. bluecalais79
    Front Dash Speakers
  7. rich_e777
    Front Dash Speakers
  8. bluecalais79
    Front Dash Speakers
  9. 94 olds vert
    Front Dash Speakers
  10. bluecalais79
    Front Dash Speakers
  11. SuperBuick
    Louver position on the hood
  12. Amanita
    Rough idle/ volt drop
  13. Jscott
  14. rich_e777
    Digi UB3 adapter
  15. 55trucker
  16. phewop118
  17. 94 olds vert
    Digi UB3 adapter
    This thread is 15 years old.
  18. rich_e777
    Digi UB3 adapter
  19. The LQ1 timing stuff looks intimidating until it's laid out step by step. That video saves a lot of random forum digging.
  20. hazelspindle3
    New member with 98 lumina
  21. hazelspindle3
  22. calmspindle6
    New to this place. Hello.
  23. That video is one of those rabbit holes where you start with a tensioner and end up learning the whole LQ1 timing setup. Pretty handy to have around.
  24. covefinch9
  25. A reman label really muddies the water, so the broadcast code is the one piece that settles it. A logger that connects with the wrong stream can look believable right up until it sends you chasing nonsense.
  26. Those convertible-specific seals and interior bits can be a real scavenger hunt, but an 80k car that's been garaged is a solid starting point. Getting him one more ride in it would be pretty special.
  27. mossyelk
  28. briskshovel88
