This thread is 15 years old.
Digi UB3 adapter
The LQ1 timing stuff looks intimidating until it's laid out step by step. That video saves a lot of random forum digging. - Yesterday
hazel_trout changed their profile photo - Last week
ivan_anvil joined the community -
mossyelk joined the community -
briskshovel88 joined the community -
charm.li free forever
89 olds swaybar
This is a great educational video about these motors. You can skip forward to the appropriate section for any questions.
