I will remember not to use the impact on the new ones and use the socket. I will have to torque to specs anyhow the nut on top - Yesterday
Brake Line Size
The strut kit i have says OEM # 27034. This is the same kit that Autozone used to rent. I see ebay has the same kit listed as T&E Tools AT185. - Last week
This tool acts as a handle that screws onto the threads on the end of the strut. Once installed you can move the strut around so you can center the strut in the hole. On my 96 the strut shaft wanted to move in the direction of the motor. I had to use pieces of wood wedged between the inner-fender and the strut spring to center the strut shaft so the removal tool would fit down the hole to the nut. Without this positioning tool i could not have changed my front struts. The guy in that video did not have this tool. -
This tool in my kit was useless because it was too big to fit in the hole. Maybe this tool will work on your 98?
