White93z34 Posted May 24, 2025 Report Posted May 24, 2025 Basically the 2 big ICs are the biggest areas of concern. For me over the long run reflowing the joints is a temporary fix, I've had more success in adding some good solder. Recently I've purchased a proper desoldering tool and I'll just clean out the solder and start over with fresh mdpierce8 1 Quote
GnatGoSplat Posted May 24, 2025 Report Posted May 24, 2025 I originally did the 2 ICs, but then had to do it again not too long after (can't remember if months or years). So I ended up just reflowing every single joint and that kept it working well over a decade. I added flux to every joint and added a little new solder, but I didn't remove any old solder. If you plan to desolder first, then I'd recommend finding vintage 60/40 solder (with lead). If all you can get is RoHS solder, then it'd be a good idea to keep the old solder as it still has lead. Leadless RoHS solder are famous for solder joints going bad over time. Checking the caps is a good idea. I didn't do that at the time, but I've had to change out enough electrolytic caps to know they have a finite life. mdpierce8 1 Quote
mdpierce8 Posted May 25, 2025 Report Posted May 25, 2025 It worked! Thanks for all the pointers. All I did was reflow the old solder so I left the rear deck cover off for now, the cover was very sun damaged anyway. But at least I have a working key fob now. IMG_7474.mov pwmin, White93z34, GnatGoSplat and 1 other 4 Quote
Psych0matt Posted May 27, 2025 Report Posted May 27, 2025 I should get mine working, one more thing I haven’t bothered with in years, but now that I fixed my sunroof relay might as well figure this one out as well. Quote
architect Posted June 26, 2025 Report Posted June 26, 2025 Reviving this thread! So would the receiver be at the back under upholstery or passenger door for my 1995 Regal GS? Can't seem to figure out how to get under the upholstery as well unless I just gotta pry and yank, which makes me nervous for this old car... Quote
jiggity76 Posted June 26, 2025 Report Posted June 26, 2025 (edited) 23 minutes ago, architect said: Reviving this thread! So would the receiver be at the back under upholstery or passenger door for my 1995 Regal GS? Can't seem to figure out how to get under the upholstery as well unless I just gotta pry and yank, which makes me nervous for this old car... The receivers are mounted up in the back glass shelf area. The upper rear seatback needs to come out...which means the shelf also needs to come out. Then, to get the shelf out, you have to pull the rear quarter glass interior plastics that go around the glass. GM layered these pieces. Here's my 93 Grand Prix STE sedan. It won't be identical, but it will be the same process and in the same location. That black box up against the rear glass...that's the receiver. Edited June 26, 2025 by jiggity76 architect 1 Quote
GnatGoSplat Posted June 26, 2025 Report Posted June 26, 2025 (edited) 1 hour ago, architect said: Reviving this thread! So would the receiver be at the back under upholstery or passenger door for my 1995 Regal GS? Can't seem to figure out how to get under the upholstery as well unless I just gotta pry and yank, which makes me nervous for this old car... If it's a coupe, it's where @Black92GS showed a few posts up. If a sedan, on the back deck as @jiggity76 shows. Regal coupes had a much smaller rear deck due to the more vertical backglass. Top is sedan, bottom is coupe. Edited June 26, 2025 by GnatGoSplat architect and jiggity76 1 1 Quote
jiggity76 Posted June 26, 2025 Report Posted June 26, 2025 45 minutes ago, GnatGoSplat said: If it's a coupe, it's where @Black92GS showed a few posts up. If a sedan, on the back deck as @jiggity76 shows. Regal coupes had a much smaller rear deck due to the more vertical backglass. Top is sedan, bottom is coupe. That's interesting. My bad...I thought they were all in the same location. My Cutlass coupe is also in the back shelf area. The rear glass is allowing more space for it I'm sure than a Regal coupe. architect 1 Quote
GnatGoSplat Posted June 26, 2025 Report Posted June 26, 2025 I didn't know either until @Black92GS's reply earlier in the thread. It's also elsewhere on the convertibles since there's no rear deck. Quote
architect Posted June 26, 2025 Report Posted June 26, 2025 (edited) How does the seat first get removed? Sorry not very car inclined here. Mine is the 4 door sedan. Edited June 26, 2025 by architect Quote
94 olds vert Posted June 26, 2025 Report Posted June 26, 2025 15 minutes ago, architect said: How does the seat first get removed? Sorry not very car inclined here. Mine is the 4 door sedan. Should be 2 or 3 bolts on the seat bottom facing the rear of the front seats. Remove the bottom seat cushion and then you will see the bolts that hold the back seat cushion on. jiggity76, White93z34 and architect 3 Quote
architect Posted June 28, 2025 Report Posted June 28, 2025 (edited) Got the lower and upper seats off and see the plastic plugs holding down the upholdstery. Do I yank these out or is there a technique for 'em? Don't wanna ruin these! They appear to be the "xmas tree" style that goes in once. Not centre pinion to loosen or any form of spring action. Edited June 29, 2025 by architect Quote
GnatGoSplat Posted June 29, 2025 Report Posted June 29, 2025 Unfortunately, they are indeed Xmas tree type. I used a standard trim panel puller to remove them. I was able to reuse mine after pulling, but it's possible they lost some strength after pulling. architect and 94 olds vert 2 Quote
architect Posted June 29, 2025 Report Posted June 29, 2025 Thanks for the help. I got them off with a puller but couldn't do it without some damage. Hope they stay snug once I get 'em back in. I'm at the plastic trim around the glass now before I can lift the felt cover out. Any tricks with the trim? I don't see any fasenters so think I just need to pry off? Quote
GnatGoSplat Posted June 29, 2025 Report Posted June 29, 2025 Yeah, I hate those one time use clips. I don't have the factory service manual, only parts catalogs, but there appear to be no fasteners for that part other than one staple (#3) towards the bottom. Not sure if that staple has to come out. It looks like the same annoying clip setup my Cutlass Supreme has along the top edge. If I recall the metal clip parts have sharp barbs and dig into the plastic, so some wear to the plastic happens every time you pull it. If the plastic tabs don't break off, they usually go back on and fit well enough, but it's not something you want to have to pull often. Looks like something near the top of the quarter glass and I'd guess that's an xmas tree type clip. architect 1 Quote
architect Posted June 29, 2025 Report Posted June 29, 2025 (edited) Thanks that diagram helps. Got my neighbor to help. Putting these photos up for anyone else that finds this thread. Two red clips at the top of door, one white xmas tree clip, and a clip on the inside of the car that requires you pull the panel forward to release. Edited June 29, 2025 by architect GnatGoSplat 1 Quote
architect Posted June 29, 2025 Report Posted June 29, 2025 The board looks pretty clean...can't see any damage at all and starting to doubt its this issue...? Quote
GnatGoSplat Posted June 29, 2025 Report Posted June 29, 2025 I've never been able to SEE the bad solder joints, and I think the glossy conformal coating would probably hide them if there were some. I've always just cleaned off the coating and resoldered the joints anyway. That's always worked. I think most people who have done it had the same experience. architect 1 Quote
architect Posted June 30, 2025 Report Posted June 30, 2025 I grounded the black and white cable in the the trunk and the locks switched on and off so reciever is okay. Should have started with this test but learned something from ripping up the car. Now to figure if it's my fob or just gotta be programmed. Anyone have success with third party fobs? Quote
architect Posted June 30, 2025 Report Posted June 30, 2025 Can't seem to reprogram my current fob. When in programming mode clicking any buttons on the fob do nothing. I'm definitely in programming mode because they locks activate when ground the b/w wires. New tested batteries in fob and the circuits look clean. Thoughts? Quote
GnatGoSplat Posted June 30, 2025 Report Posted June 30, 2025 Locks cycling just means part of the receiver is okay. Doesn't necessarily mean it's receiving a signal correctly. I've had bad ones do that too. Although it's definitely easier to rule it in or out with multiple fobs. architect and White93z34 2 Quote
architect Posted June 30, 2025 Report Posted June 30, 2025 (edited) I noticed the metal tab was depressed on one of the batteries. Tab broke off as soon as I gently tried to pry it back upwards. Tab was barely hanging on. Does anyone know if these batteries run in parallel or series? If series then maybe this could the issue. Edited June 30, 2025 by architect Quote
