GhrarhG Posted September 14, 2009 Report Posted September 14, 2009 I'm not sure if there's room under the gen 2 intake. Never tried them, then went gen3. The can be made to work in a gen 3. You would need the following brackets. http://wot-tech.com/shop/all/l67-injector-rail-brackets/prod_119.html You'd also have to splice in different connectors. Might be more effort than it's worth for your application Mach 5 1 Quote
intern8tion9l Posted September 14, 2009 Report Posted September 14, 2009 i honestly don't remember what year they came out of, but it was definitely a grand prix. i got all the info from people on here, so i'm sure you won't have a problem doing the same. don't remember exactly how much i paid either, but i think it was less than $50 Quote
Mach 5 Posted September 21, 2009 Author Report Posted September 21, 2009 I ordered the yellow top ford injectors remans. Should be here by the end of the week. I just located a radiator and a possible exhaust manifold. I ordered one from GM but it was the n/a one not the turbo even though it was listed as a turbo manifold. Quote
Mach 5 Posted September 22, 2009 Author Report Posted September 22, 2009 Does anyone know where I can get the turbos cooling feeds from? I was thinking the line that comes from that return pipe(for return)and the line that lines along the pass side wheel well by the crank pulley(for inlet). Quote
Mach 5 Posted September 22, 2009 Author Report Posted September 22, 2009 Its got those brass fittings on the turbo for the water lines but where do I tap into on the engine for these? The turbo engine already has the lines integrated in. The main problem is where do I get the water inlet to the turbo from? Im going to borrow the return from the pipe by the valve cover. -I ordered a Greddy Type S BOV, TGP rad, and manifolds. Let me know what you may think on the BOV. I watched some comparison videos on youtube and this had that Fast & Furious sound so I liked it. Now I just need to figure out the cooling for the turbo, air filter setup, and the rest should be pretty stright forward. Quote
intern8tion9l Posted September 22, 2009 Report Posted September 22, 2009 i wanted the type s, as i think it has a great sound, but ended up with the type rs since the s was discontinued....where did you find it? for the air filter all you need is a k&n right on the turbo inlet. for the coolant, one line comes across the top near the valve cover, and one goes along the bottom to the oil cooler at the oil filter(near the turbo oil lines). don't have a pic of that at the moment..... Quote
slick Posted September 23, 2009 Report Posted September 23, 2009 i wanted the type s, as i think it has a great sound, but ended up with the type rs since the s was discontinued....where did you find it? for the air filter all you need is a k&n right on the turbo inlet. for the coolant, one line comes across the top near the valve cover, and one goes along the bottom to the oil cooler at the oil filter(near the turbo oil lines). don't have a pic of that at the moment..... Did you do a harness tuck?!! Quote
Mach 5 Posted September 23, 2009 Author Report Posted September 23, 2009 The BOV I got is a used unit. The thing is though, I don't have that return pipe by the valve cover so Im just going to T it off somewhere along that line. Its the feed that Im worried about. As for a wire tuck, how much can you tuck? I thought that the GM harness setup was sufficient enough but your car is so damn clean so maybe mine needs it. Was yours the actually a turbo engine or is it converted? Also, do you have a pic of the fuel lines? Mine look like they are too close to the turbo. Quote
intern8tion9l Posted September 23, 2009 Report Posted September 23, 2009 Yes that is an entire tgp engine. You're right, i think your fuel lines will be too close, the lines I have are from the tgp as well and have more of an arc. What is this harness tuck you speak of? Quote
slick Posted September 23, 2009 Report Posted September 23, 2009 What is this harness tuck you speak of? Refer to this: http://www.6gc.net/forums/index.php?showtopic=44927 Basically, hide as much wiring as possible. Sometimes requires modifying the harness to extend wires. Quote
intern8tion9l Posted September 24, 2009 Report Posted September 24, 2009 Well obviously didn't do it since I didn't even know what it was. Lol Quote
slick Posted September 24, 2009 Report Posted September 24, 2009 Yeah, just the engine bay itself looks pretty clean, and I couldn't find a harness to save my life. Quote
kuntzie Posted September 24, 2009 Report Posted September 24, 2009 the wire harness is tucked under the intake on the 3.1L.. super clean Quote
Mach 5 Posted September 30, 2009 Author Report Posted September 30, 2009 I actually used some stuff from that link when I built my AE86 and swapped in the 20v. Funny you posted it Radiator and manifolds should be here in a couple of days. Someone had them on TGPforums. I have everything else, just waiting for that. Quote
Mach 5 Posted October 3, 2009 Author Report Posted October 3, 2009 How hard is it to fit the turbo downpipe? Im having fitment issues. Does anyone have a pic of this? Quote
intern8tion9l Posted October 5, 2009 Report Posted October 5, 2009 mine went right in, but it does sit really close to everything. if i beat the darkness home tonight i'll snap a pic Quote
Garrett Powered Posted October 5, 2009 Report Posted October 5, 2009 I built a 2.5 DP and learned that the easiest way to get one installed is rock the motor forward and drop it straight down between the motor and firewall. it nestles down right next to the trans dipstick if you got an auto. Quote
Mach 5 Posted October 6, 2009 Author Report Posted October 6, 2009 I got it in. I don't know why I couldn't get it to fit the other day but today it just went right in. Now all I have to do is tangle with the coolant lines and fit the turbo and mess with the pipe for the egr. For the egr, I guess that there is a different pipe thats fits because the n/a pipe is too long. Do you think I could just get a block off plate for the intake and plug the bung on the crossover and just bypass the issue or do I need the EGR w the factory programming? The other thing that got me wondering about is the MAP sensor plug, Its different from the n/a MAP sensor. I just modified the plug to fit the turbo one assuming that the wiring was the same. Quote
intern8tion9l Posted October 6, 2009 Report Posted October 6, 2009 you'll prob need the egr if you're running the stock programming. i got rid of mine, but had the chip done too Quote
Mach 5 Posted October 14, 2009 Author Report Posted October 14, 2009 waiting on the chip. I had it running with the tuned n/a chip but it won't start without it. I sent the chip to ben to be reflashed with the stock tgp prgramming. Im going to try run it without the egr. Quote
intern8tion9l Posted October 14, 2009 Report Posted October 14, 2009 awesome! i want to see this thing in person Quote
Mach 5 Posted October 14, 2009 Author Report Posted October 14, 2009 Ben just shipped the chip today so I should have it very soon. Quote
Mach 5 Posted October 16, 2009 Author Report Posted October 16, 2009 Thanks! That chip should be here tomorrow. Quote
