Afubar Posted November 7, 2007 Report Share Posted November 7, 2007 Okay, It was worth a try anyway. Good Luck. Quote Link to comment Share on other sites More sharing options...
ManicMechanic Posted November 7, 2007 Report Share Posted November 7, 2007 CPS. Quote Link to comment Share on other sites More sharing options...
joey b Posted November 8, 2007 Report Share Posted November 8, 2007 I'm still waiting for you to confirm that to be the plug that connects the CPS to the ICM.... Quote Link to comment Share on other sites More sharing options...
pwmin Posted November 8, 2007 Report Share Posted November 8, 2007 butt plug Quote Link to comment Share on other sites More sharing options...
joeld Posted November 9, 2007 Report Share Posted November 9, 2007 Just for the hell of it look at your power steering high pressure hose at the rack and see if there is a sensor in the hose. I have seen these on a lot W-bodys, my 95 GP does not have one though. Probably should have called it a "switch" instead of a sensor but you get what I'm talking about. Good luck Quote Link to comment Share on other sites More sharing options...
Stevo Posted November 9, 2007 Report Share Posted November 9, 2007 Underhood Light Plug... don't make me come down there. Quote Link to comment Share on other sites More sharing options...
Psych0matt Posted November 9, 2007 Author Report Share Posted November 9, 2007 Underhood Light Plug... don't make me come down there. it is not the effing under hood light! I just went and compared them, and although similar, this one is wider. it looks the same as the ICM side of the CPS plug (purple and yellow, same head) but these wires arent twisted, and I'm almost 100% sure that the original plug end is the one plugged into the ICM (dirty like the other plug on the ICM) Quote Link to comment Share on other sites More sharing options...
Brian P Posted November 9, 2007 Report Share Posted November 9, 2007 WAYYYY OFF TOPIC. Keep it in the whatever section!!! Quote Link to comment Share on other sites More sharing options...
badassoldspower Posted November 13, 2007 Report Share Posted November 13, 2007 Ok it could possibly be a crank sensor wire, for the sensor on the back of the block, our cars have 2 crank sensors, one low resolution, one high resolution, it will run with the low without the high but not vice versa, also check and see if it is a variable effort steering plug, your car is wired for it, it just may not be mechnically equipped with it so the plug could be irrelevant. Good luck to you sir! Quote Link to comment Share on other sites More sharing options...
Psych0matt Posted November 13, 2007 Author Report Share Posted November 13, 2007 would a 96 block have the second sensor plug, and since I have a 94 ecm and everything, not have a spot for the plug? Quote Link to comment Share on other sites More sharing options...
AWeb80 Posted November 13, 2007 Report Share Posted November 13, 2007 My First Thought Was CPS Wire. You Might Have An Extra. Quote Link to comment Share on other sites More sharing options...
ManicMechanic Posted November 13, 2007 Report Share Posted November 13, 2007 That is my thought Adam. Quote Link to comment Share on other sites More sharing options...
