  1. Yesterday
  2. 55trucker
  3. 55trucker
  4. crazyd
  5. crazyd
  6. Last week
  7. Schurkey
  8. 55trucker
  9. crazyd
  10. crazyd
  11. GnatGoSplat
  12. 55trucker
  13. I greased the outer tie rod and ball joint, why is it still making this noise? 20250502_104001.mp4
  14. crazyd
    '92 GTP DIC - no fuel data?
  15. Earlier
  16. crazyd
  17. Schurkey
  18. bluecalais79
  19. crazyd
  20. Schurkey
  21. I found a replacement plug for my air temp sensor on a junkyard car and am trying to get the wires out of it. I've got a round multi-tool for this that I got on Amazon that has five different tools on it but so far it looks like only the smallest straight-blade tool fits. I pushed the wires through the front of the replacement plug but that doesn't seem like the right way to do it.
  22. SuperBuick
    Bluetooth Module DIY
  23. rich_e777
  24. Black92GS
  25. SuperBuick
  26. White93z34
    TRW Keyless Entry module
  27. Black92GS
  28. GnatGoSplat
