Need help with brakes
Psych0matt replied to brock9334z's topic in Brakes/Suspension/Steering/Wheels/Tires
Just go to the appropriate section and hit "start new topic" - Today
Schurkey reacted to a post in a topic: Need help with brakes
GnatGoSplat reacted to a post in a topic: hey guys! Here is my 03 monte with a 3.6 and 6t70 swap!
Ggfreeda replied to brock9334z's topic in Brakes/Suspension/Steering/Wheels/Tires
Oh well I wasn’t sure how the website works -
you should probably start your own thread for that... -
I'm having trouble finding a thermostat housing for my 1995 Oldsmobile Cutlass Supreme SL 3.4L with DOHC. The part is an aluminum casting located at the front left of the engine, but it's discontinued. What can I do? I've contacted junkyards from Texas to Tennessee and searched internet extensively. -
Ggfreeda joined the community
94 olds vert reacted to a post in a topic: Need help with brakes
Hello I’m messaging you to find out if I have the complete impala vehicle how much fabrication will I need to do for the swap.Mine is a 2006 Monte Ss with a 5.3 but I wanna go 3.6 - Earlier
Sonoma77 joined the community
awesome!
SSWBody joined the community
Wow that car is awesome!
