  2. 55trucker
    Need help with brakes
  3. White93z34
  4. My parents have 95 Cutlass Supreme drop top with the 3.4 V6. They drove it today and the brakes went to the floor. Car has an honest 35,000 miles on it. It seems it needs a master cylinder. Car has ABS can anyone advise me how to bleed the system? I understand doing the bench bleed of the new master, my concern is bleeding the rest of the system. Any assist you are able to offer will be greatly thanked. I will be driving 700 miles to do this so they do not attempt to drive the car to a garage while using the parking brake. Thanks in advance for any advice Brock
  5. Yesterday
  6. pwmin
  7. Last week
  8. 89-W-Body-Regal
  9. 55trucker
  10. White93z34
  11. Schurkey
  12. Toughluck30
  13. 55trucker
  14. This is a 14 year long shot… But I’m in need of those dome light switches, are you still a member of this club and do you still have any left?
  15. Spoonnman
  16. Earlier
  17. Spoonnman
  18. White93z34
  19. Hey! Had my beautiful GTP for bit now and I am just wondering on the available for transmission rebuild kits for the MT. I know I remember seeing they were like basically impossible to get a long time ago but does anyone know of any that have been manufactured again? For the record it is the 3.4L DOHC V6 with a 5 speed, coupe, the only option it came in I believe. I would also like to learn some more about it if anyone has some random facts haha.
  20. Mach 5
    awesome!
  21. Bake82
  22. rich_e777
  23. SuperBuick
  24. 94 olds vert
    My Turbo 99 Z34 Monte Carlo
    Wow that car is awesome!
  25. White93z34
  26. Schurkey
  27. SuperBuick
  28. SuperBuick
  29. babyteef
