Ok well I found out from another post from 2019 this is what strut I have. The seat is fastened to the top of the knuckle assembly. That is why I can’t install the tool inside down into the strut tower to remove the strut closure nut that is supposed to remove the cartridge because the seat is covering any access to fit the cartridge tool down into the strut tower. Do I need to remove the whole strut assembly? *The manual says do not service the strut unless the weight of the vehicle is on the suspension. But some shops have the wall mount spring compressors for that* Seat on top of the knuckle. actual knuckle that the cartridge fits into. - Today
Need help with brakes
Ggfreeda replied to brock9334z's topic in Brakes/Suspension/Steering/Wheels/Tires
Oh well I wasn’t sure how the website works -
Psych0matt replied to brock9334z's topic in Brakes/Suspension/Steering/Wheels/Tires
you should probably start your own thread for that... -
I'm having trouble finding a thermostat housing for my 1995 Oldsmobile Cutlass Supreme SL 3.4L with DOHC. The part is an aluminum casting located at the front left of the engine, but it's discontinued. What can I do? I've contacted junkyards from Texas to Tennessee and searched internet extensively. -
Ggfreeda joined the community
94 olds vert reacted to a post in a topic: Need help with brakes
rich_e777 reacted to a post in a topic: `89 TGP joining the collection
^ You referring to the tension actuator? - Earlier
Sonoma77 joined the community
awesome!
SSWBody joined the community
Wow that car is awesome!
