  2. Describe the *noise* you are hearing.......you say that this was heard when the original spring was still in place? Does the *replacement* spring still have the rubber pads glued to the ends of the leaf?
  3. The spring is installed and functional, the car a bit higher in the rear but I expected that. What I didn't expect is for the noise to return after about a day. I am wonder if it is the point where the spring contacts the plastic isolator and or where the the isolator sit in the bracket. Any ideas are appreciated.
  4. Yesterday
  5. 55trucker
  6. 55trucker
  7. crazyd
  8. crazyd
  9. Last week
  10. Schurkey
  11. 55trucker
  12. crazyd
  13. crazyd
  14. GnatGoSplat
  15. 55trucker
  16. I greased the outer tie rod and ball joint, why is it still making this noise? 20250502_104001.mp4
  17. crazyd
    '92 GTP DIC - no fuel data?
  18. Earlier
  19. crazyd
  20. Schurkey
  21. bluecalais79
  22. crazyd
  23. Schurkey
  24. I found a replacement plug for my air temp sensor on a junkyard car and am trying to get the wires out of it. I've got a round multi-tool for this that I got on Amazon that has five different tools on it but so far it looks like only the smallest straight-blade tool fits. I pushed the wires through the front of the replacement plug but that doesn't seem like the right way to do it.
  25. SuperBuick
    Bluetooth Module DIY
  26. rich_e777
  27. Black92GS
  28. SuperBuick
  29. White93z34
    TRW Keyless Entry module
