  2. The spring is installed and functional, the car a bit higher in the rear but I expected that. What I didn't expect is for the noise to return after about a day. I am wonder if it is the point where the spring contacts the plastic isolator and or where the the isolator sit in the bracket. Any ideas are appreciated.
  3. Yesterday
  4. 55trucker
  5. 55trucker
  6. crazyd
  7. crazyd
  8. Last week
  9. Schurkey
  10. 55trucker
  11. crazyd
  12. crazyd
  13. GnatGoSplat
  14. 55trucker
  15. I greased the outer tie rod and ball joint, why is it still making this noise? 20250502_104001.mp4
  16. crazyd
    '92 GTP DIC - no fuel data?
  17. Earlier
  18. crazyd
  19. Schurkey
  20. bluecalais79
  21. crazyd
  22. Schurkey
  23. I found a replacement plug for my air temp sensor on a junkyard car and am trying to get the wires out of it. I've got a round multi-tool for this that I got on Amazon that has five different tools on it but so far it looks like only the smallest straight-blade tool fits. I pushed the wires through the front of the replacement plug but that doesn't seem like the right way to do it.
  24. SuperBuick
    Bluetooth Module DIY
  25. rich_e777
  26. Black92GS
  27. SuperBuick
  28. White93z34
    TRW Keyless Entry module
  29. Black92GS
