Schurkey reacted to a post in a topic: Need help with brakes
GnatGoSplat reacted to a post in a topic: hey guys! Here is my 03 monte with a 3.6 and 6t70 swap!
Ggfreeda replied to brock9334z's topic in Brakes/Suspension/Steering/Wheels/Tires
Oh well I wasn’t sure how the website works -
Psych0matt replied to brock9334z's topic in Brakes/Suspension/Steering/Wheels/Tires
you should probably start your own thread for that... -
I'm having trouble finding a thermostat housing for my 1995 Oldsmobile Cutlass Supreme SL 3.4L with DOHC. The part is an aluminum casting located at the front left of the engine, but it's discontinued. What can I do? I've contacted junkyards from Texas to Tennessee and searched internet extensively. -
Ggfreeda joined the community
94 olds vert reacted to a post in a topic: Need help with brakes
^ You referring to the tension actuator? - Earlier
Sonoma77 joined the community
awesome!
SSWBody joined the community
Wow that car is awesome!
