spyder2014 joined the community - Today
Boot for sale, 93 to 95 Cutlass Supreme convertible.
spyder2014 posted a topic in Cutlass Supreme Convertible
I have a boot for these cars, I think it's called charcoal. It has a bluish tint to it good condition. Anyone interested? -
bethanycroft joined the community - Yesterday
New to this place. Hello.
Amanita reacted to a post in a topic:
Getrag 282 info
GarrettLowell joined the community - Last week
IMG_4560.MOV -
You understand that because you're dealing OBD1 the ECM mem cal's are tuned to the specific vehicle powertrain the mem-cal is plugged into for particular vehicles ECM. If one is attempting to do custom chip mods you can't just use a program such as TunerPro to alter the mem-cal, you have to burn a new eeprom blank chip (27C256) to fit into the chip housing that plugs into the mem-cal slot. To burn the chip you will need the physical Moates chip burner, a laptop with the Moates software on it to read the existing mem-cal, extract that BIn file, then you have to write the new BIN program with the Moates software & then command the burn of the new blank chip. To be honest one usually doesn't get it right the 1st time. Here is the list of GM OBD1 ECMs & the accompanying MEM-CAL ID's. Yours will the 1227727. Your engine code is *T*, the mem-cal will be for either auto or man trans. Your mem-cal has a sticker attached to the mem-cal, pull the ECM inspection cover, the mem-cal is right below the cover for easy access. The ECM is easy to recognize, open the hood, in front of right side shock tower under the plastic cover, bolted to the shock tower. https://pcmhacking.net/ludis/p4xref.html#1227727
