bama223 Posted August 8 Report Posted August 8 I have a 2000 Buick century limited with the 3.1 I bought 3.4 upper and lower intake and head's to put on it is it worth the swap Quote
55trucker Posted August 9 Report Posted August 9 There is little to be gained, you won't get the advertised 10 hp difference in the two engines, both heads are the same casting, the intake ports in the LA1 are slightly larger for more top end flow, the LA1 intake valves are so slightly larger in dia (1mm). the lower intakes are the same, the uppers are different cosmetically and they are plainly identified by the engine size cast into the plenum. The only operational difference in the uppers is the dia of the throttle body opening, the LG8 makes use of a 52mm throttle body & the LA1 uses a 56mm throttle body. As far as I know the LG8 makes use of the same rear exhaust manifold that the LA1 does, but I'm not completely sure of that. Quote
bama223 Posted August 23 Author Report Posted August 23 So basically what you are telling me is the whole top end swap thing is a waste of time I appreciate you telling me there is no need to swap it all of it's all the same Quote
55trucker Posted August 23 Report Posted August 23 Well, in a nutshell, yes...... one will not get out of an LG8 quite what the LA1 delivers. The old saying *there ain't no replacement for cubic inch displacement* still rings true. But from a totally *biased* point of view.........why go to the effort where a mom & pop sedan is concerned? Just keep it running respectably in its present format. If the car off the assembly line was a intended sports sedan with an optional handling package & an optional higher hp powertrain I can see working with that. Quote
White93z34 Posted August 24 Report Posted August 24 I mean assuming the intakes are off a compatible w car you could gain maybe a tiny bit from the larger later intakes, I think a 2000 would still have the old 3100 manifolds. but its not enough of a gain that i'd waste my time. Go get the rest of the 3400 and you are looking at some gains, but i'd still be questioning of the journey is worth the destination. Quote
