  1. Last week
  2. I have a boot for these cars, I think it's called charcoal. It has a bluish tint to it good condition. Anyone interested?
  3. GarrettLowell
    New member with 98 lumina
    That’s a pretty sweet find, especially being the second owner with only 70k on it. The interior looks like it’s held up really well too. Funny how that kind of thing matters more than flashy extras sometimes, same with online stuff. On a casino like https://tropical-casino.com/ Tropical Casino, a clean slot layout, a decent bonus screen or a small win animation can make the whole thing feel better without doing too much. Welcome to the forum, curious to see what you end up doing with it and whether you keep it mostly stock or start changing things.
  4. GarrettLowell
    New to this place. Hello.
  5. Earlier
  6. SuperBuick
    Getrag 282 info
    Quad 4 Getrag 282 for W-Body
  7. SuperBuick
    Getrag 282 info
  8. SuperBuick
    IMG_4560.MOV
  9. 1227727 and 1227730 use the same chips. One is waterproof and used in W bodies and Corvettes. 1990 is the only year to use $88 code mask. 88-89 are $6D. 91-92 is $A1. 93 is $DF. Thats for the 3.1 V6. The most common with all the data code layed out is $A1. I would use A1 to start and modify from there (because I have been tuning these for over 20 years and can do this).
  10. White93z34
  11. 55trucker
  12. bama223
  13. 55trucker
    Summer Ending Cutty meet up?
  14. White93z34
  15. Bake82
  16. 55trucker
  17. kinger_13
  18. kcac
  19. Adding some pictures because it is a very rare and very fascinating setup. Lots of pics of the engine bay exist, but Ive never found any of the engine assembly on the subframe. Enjoy!
  20. 55trucker
  21. bama223
  22. Holy Hell...how did I miss this!!!! This is pretty incredible and so glad I finally found this thread. I am here for any help.
  23. The access cover on the shock tower side, you will have to remove the ECM & then you'll see the access cover. Can't tell you for sure but the mem-cal will could very well be the AUMY, pull the ecm, remove the cover & you'll see for sure.
  24. Thank you for pointing me to the correct location. I found the ECM under the passenger-side strut tower. I uploaded three photos of it. The only label I can see is the Delphi remanufactured sticker (SVC #16198260). I don't see an obvious inspection cover or small access panel for the MEM-CAL. Before I start removing mounting bolts or unplugging connectors, can you tell me exactly which fasteners need to come off to access the MEM-CAL and read the original GM ECM service number? I don't want to damage anything or take apart more than necessary.
  25. Thanks, that's exactly the information I was looking for. I haven't physically verified my ECM yet. I'll check the passenger-side shock tower under the hood and report back with the ECM service number and MEM-CAL ID. Since my car is a 1990 Cutlass Supreme 3.1 LH0 with an automatic, can you tell me which stock MEM-CAL ID I should expect to find?
  26. You understand that because you're dealing OBD1 the ECM mem cal's are tuned to the specific vehicle powertrain the mem-cal is plugged into for particular vehicles ECM. If one is attempting to do custom chip mods you can't just use a program such as TunerPro to alter the mem-cal, you have to burn a new eeprom blank chip (27C256) to fit into the chip housing that plugs into the mem-cal slot. To burn the chip you will need the physical Moates chip burner, a laptop with the Moates software on it to read the existing mem-cal, extract that BIn file, then you have to write the new BIN program with the Moates software & then command the burn of the new blank chip. To be honest one usually doesn't get it right the 1st time. Here is the list of GM OBD1 ECMs & the accompanying MEM-CAL ID's. Yours will the 1227727. Your engine code is *T*, the mem-cal will be for either auto or man trans. Your mem-cal has a sticker attached to the mem-cal, pull the ECM inspection cover, the mem-cal is right below the cover for easy access. The ECM is easy to recognize, open the hood, in front of right side shock tower under the plastic cover, bolted to the shock tower. https://pcmhacking.net/ludis/p4xref.html#1227727
