Taz1959 joined the community
White93z34 reacted to a post in a topic: Need to know some info about replacing the strut cartridge?
Schurkey reacted to a post in a topic: Need help with brakes
GnatGoSplat reacted to a post in a topic: hey guys! Here is my 03 monte with a 3.6 and 6t70 swap!
Ggfreeda joined the community
94 olds vert reacted to a post in a topic: Need help with brakes
The 3.6 is quite an engine. The 6T70E seems to be a pretty-fair transmission, although it pisses me off that there's no serviceable filter. But giving up a V8 in a fairly-rare car to go backwards into ordinary? Re-think this. - Earlier
Sonoma77 joined the community
awesome!
Wow that car is awesome!
