  2. 55trucker
  3. 55trucker
  4. crazyd
  5. Today
  6. crazyd
  7. Yesterday
  8. Schurkey
  9. 55trucker
  10. Last week
  11. crazyd
  12. crazyd
  13. GnatGoSplat
  14. 55trucker
  15. I greased the outer tie rod and ball joint, why is it still making this noise? 20250502_104001.mp4
  16. crazyd
    '92 GTP DIC - no fuel data?
  17. Earlier
  18. crazyd
  19. Schurkey
  20. bluecalais79
  21. crazyd
  22. Schurkey
  23. I found a replacement plug for my air temp sensor on a junkyard car and am trying to get the wires out of it. I've got a round multi-tool for this that I got on Amazon that has five different tools on it but so far it looks like only the smallest straight-blade tool fits. I pushed the wires through the front of the replacement plug but that doesn't seem like the right way to do it.
  24. SuperBuick
    Bluetooth Module DIY
  25. rich_e777
  26. Black92GS
  27. SuperBuick
  28. White93z34
    TRW Keyless Entry module
  29. Black92GS
  30. GnatGoSplat
