rich_e777 reacted to a post in a topic: Mono spring delete or suggestions
The spring is installed and functional, the car a bit higher in the rear but I expected that. What I didn't expect is for the noise to return after about a day. I am wonder if it is the point where the spring contacts the plastic isolator and or where the the isolator sit in the bracket. Any ideas are appreciated. - Yesterday
crazyd reacted to a post in a topic: '92 GTP, Why is it making this noise?
Arthur joined the community
GnatGoSplat started following '92 GTP, Why is it making this noise? and Mono spring delete or suggestions
