Need help with brakes
Are you absolutely positive that there is not a rusted out/broken, brake line, hose or caliper? I know it has low miles but what you describe sounds way more like a break in the system then a failed master Treat it like any other master cylinder, bench bleed it, install it it has a couple extra bleeders on the master, start there and then work from the back to front. a Vacuum bleeder would make it easier. - Today
jiggity76 reacted to a post in a topic: 1992 Grand Prix GTP Manual Transmission rebuilding?
pwmin reacted to a post in a topic: 1992 Grand Prix GTP Manual Transmission rebuilding?
55trucker started following hey guys! Here is my 03 monte with a 3.6 and 6t70 swap!
Where can I purchase this part? - Earlier
Sonoma77 joined the community
awesome!
SSWBody joined the community
Route41 joined the community
teemancanada joined the community
Autopia joined the community
Wow that car is awesome!
