  2. Ggfreeda
    Need help with brakes
    Oh well I wasn’t sure how the website works
  3. Psych0matt
    you should probably start your own thread for that...
  4. Ggfreeda
    I'm having trouble finding a thermostat housing for my 1995 Oldsmobile Cutlass Supreme SL 3.4L with DOHC. The part is an aluminum casting located at the front left of the engine, but it's discontinued. What can I do? I've contacted junkyards from Texas to Tennessee and searched internet extensively.
  5. Yesterday
  6. Last week
  7. 55trucker
  8. White93z34
  9. My parents have 95 Cutlass Supreme drop top with the 3.4 V6. They drove it today and the brakes went to the floor. Car has an honest 35,000 miles on it. It seems it needs a master cylinder. Car has ABS can anyone advise me how to bleed the system? I understand doing the bench bleed of the new master, my concern is bleeding the rest of the system. Any assist you are able to offer will be greatly thanked. I will be driving 700 miles to do this so they do not attempt to drive the car to a garage while using the parking brake. Thanks in advance for any advice Brock
  10. pwmin
  11. 89-W-Body-Regal
  12. 55trucker
  13. White93z34
  14. Schurkey
  15. Toughluck30
  16. 55trucker
  17. Earlier
  18. This is a 14 year long shot… But I’m in need of those dome light switches, are you still a member of this club and do you still have any left?
  19. Spoonnman
  20. Spoonnman
  21. White93z34
  22. Hey! Had my beautiful GTP for bit now and I am just wondering on the available for transmission rebuild kits for the MT. I know I remember seeing they were like basically impossible to get a long time ago but does anyone know of any that have been manufactured again? For the record it is the 3.4L DOHC V6 with a 5 speed, coupe, the only option it came in I believe. I would also like to learn some more about it if anyone has some random facts haha.
  23. Mach 5
    awesome!
  24. Bake82
  25. rich_e777
  26. SuperBuick
  27. 94 olds vert
    My Turbo 99 Z34 Monte Carlo
    Wow that car is awesome!
  28. White93z34
  29. Schurkey
