90sEraWhips reacted to a post in a topic: Rear spring leaf
90sEraWhips reacted to a post in a topic: Placement of Jack and Jack Stands
90sEraWhips reacted to a post in a topic: Rack/Pinion Replacement 1990 Lumina
90sEraWhips started following Rack/Pinion Replacement 1990 Lumina
Which tool is that because when I’ve tried to use the strut service tool kit from the dealership that was for these cartridges according to my Buick shop manual. Here are the steps I took: let me know if i am missing anything because it’s my first time doing this and i was not successful. - First I removed the strut mounting plate with the 3 nuts. - Next I removed the top nut for the cartridge with an impact socket. The special socket and Torx socket didn’t work. I am assuming because it’s corrosive. It still came off with the impact the nut. - Then I removed the rubber strut mount bumper prying it off with a screw driver. - Next the service manual says to remove the jounce bumper (the little foam bumper)I didn’t see that on mine. That must have never been reinstalled when we had a shop done the cartilage years ago. - Next I tightened the strut extension bar onto the top of the strut cartridge where the nut goes on top of the shaft. The extension bar let me push down on the spring to compress it with the wheel on the ground. -I then removed that tool as soon as I compressed the cartridge down and it was tough because the cartridge would move side to side with that tool when I was trying to loosen it. When it came time to use that other extension bar with the closure nut socket on it to loosen the cartridge closure nut I couldn’t fit that bar down into the strut tower from the top because I had no access to fit it down into the tower hole. I think it’s because the black seat that is fastened to the top of the knuckle is covering the hole so it won’t let me access the closure nut to loosen the cartridge tool. I don’t know why but there is another dealer tool by Kent Moore to actually service the whole knuckle too. It says you need to remove the whole knuckle to use the spring compressor. In this video the guy makes it look easy. He just fits the cartridge tool down in the tower and out comes the cartridge. It wasn’t like that on my regal. So I stopped at the point where I couldn’t get the bar to fit down into the tower to remove the cartridge. PS. Thank you for the kind information about removing the oil that it’s only by choice not required to do so. -
Taz1959 joined the community
White93z34 reacted to a post in a topic: Need to know some info about replacing the strut cartridge?
Schurkey reacted to a post in a topic: Need help with brakes
GnatGoSplat reacted to a post in a topic: hey guys! Here is my 03 monte with a 3.6 and 6t70 swap!
Ggfreeda joined the community
The 3.6 is quite an engine. The 6T70E seems to be a pretty-fair transmission, although it pisses me off that there's no serviceable filter. But giving up a V8 in a fairly-rare car to go backwards into ordinary? Re-think this. - Earlier
Sonoma77 joined the community
awesome!
Wow that car is awesome!
