The passenger side dash speaker in the Grand Prix (91, 2dr SE 3.1L) has built a dang house on the fritz. Sounds like someone's making digital popcorn in it whenever I leave the radio on for more than a couple minutes. I'd like to replace both the dash speakers (I'm not a car audio junkie, I'd be fine with some $40 ones from Walmart or something). Does anyone here have any experience with removing and replacing them? I didn't want to jump into it blind. If it turns out I would need to remove any big parts of the dash or something I'd pay someone to do it. Thanks guys.
The entire dash pad has to be removed.  There are 2 bolts underneath the instrument cluster hood and there is one inside the glove box that's recessed up inside a hole. The bolts are all 7mm. Once you remove the bolts, lift up firmly on the dash pad and pull it toward you. NOTE: If your car has a heads up display, there are additional steps to this.
