crunkGP96 Posted June 10, 2013 Report Posted June 10, 2013 Hey guys, I am going to install an alpine iva d 310 in my 95 gtp but I was wondering what method have you all used to retain steering wheel controls. I'm not sure a universal steering wheel control adapter will work since the car is older. I've had this radio for a long time uninstalled and I think its about time I install it but I'd really like to keep the steering wheel controls since they still work. Ive seen on the 97 & up gp where they somehow tapped the wires with an aftermarket radio to retain the steering wheel controls. Any help is appreciated. Thanks! Sent from my HTCEVODesign4G using Tapatalk 2 Quote
Psych0matt Posted June 11, 2013 Report Posted June 11, 2013 Do you have a remote for the stereo? If so, get THIS I have one for my oddball aftermarket dvd head unit, works great. You need a remote to program it, because it basically uses your buttons as if it were a universal remote that learns from the stereo remote. Quote
crunkGP96 Posted June 14, 2013 Author Report Posted June 14, 2013 Do you have a remote for the stereo? If so, get THIS I have one for my oddball aftermarket dvd head unit, works great. You need a remote to program it, because it basically uses your buttons as if it were a universal remote that learns from the stereo remote. Yes I do, I know I should just use the remote but i really like keeping everything like factory. Thanks for the link! looks like that might work for me Quote
Senor PuffPuff Posted July 11, 2013 Report Posted July 11, 2013 You can also pick up a steering wheel control kit from most car audio places which will allow you to keep your steering wheel controls. I forget where I've seen them though other than Best Buy but I don't think Best Buy carries car audio stuff anymore. Not around here, at least. Also, Crutchfields carries them... http://www.crutchfield.com/S-Ax34aXESnkl/g_118900/Steering-Wheel-Audio-Control-Adapters.html jimj64 1 Quote
yorxs Posted August 15, 2013 Report Posted August 15, 2013 This is what I use in my 93 GTP: http://www.pac-audio.com/productDetails.aspx?ProductId=207&CategoryID=29 Your Alpine must have a "remote in" jack. There is a wire from your steering wheel controls that will connect to this adapter. The adapter has a headphone jack that plugs into the "remote in" on your stereo. If your Alpine does not have a remote in jack, then you can use the infared version of the adapter: http://www.pac-audio.com/productDetails.aspx?ProductId=212&CategoryID=29 I used to have the infared version before I got my new head unit. I found if sunlight was shining on the small IR blaster that is comes with, the deck would not be able to see the infared signal, so I switched to a deck that had a wired remote input. Quote
