meltboy1 Posted March 9, 2009 Report Share Posted March 9, 2009 My TGP leaks in the truck pretty bad, where is a common place that they leak, and how do I easily find the leak? I am thinking it is probably coming from the tail light... Quote Link to comment Share on other sites More sharing options...
GOT2B GM Posted March 9, 2009 Report Share Posted March 9, 2009 On my old Z34 the trunk used to leak at a seam that was halfway down the "rain gutter" between the trunk seal and the quarter panel. Never had any leaks in the TGP Quote Link to comment Share on other sites More sharing options...
CSI_MuNkY Posted March 10, 2009 Report Share Posted March 10, 2009 On my old Z34 the trunk used to leak at a seam that was halfway down the "rain gutter" between the trunk seal and the quarter panel. I thought the GTP was leaking in the same spot, but I gooped it up with silicone only to discover that it was coming from somewhere closer to the rear window. If mine gets worse I will probably take it to a leak expert. Jamie Quote Link to comment Share on other sites More sharing options...
Skunkworks_Zed Posted March 10, 2009 Report Share Posted March 10, 2009 On my old Z34 the trunk used to leak at a seam that was halfway down the "rain gutter" between the trunk seal and the quarter panel. My '93 SE leaked there aswell. It also leaked around the tailight seals, the bodyseam behind the tailights, and the water poured over the weather stripping since it was old and shrunk, and the trunklid needed to be adjusted down. I say "leaked" because after lots of tracking down, they are all fixed. My '95 GTP leaks pretty bad though... so back to tracking leaks for me. I bent the little tab on the sparetire well plug, popped it up with a hammer, and a waterfall started Quote Link to comment Share on other sites More sharing options...
Skunkworks_Zed Posted March 10, 2009 Report Share Posted March 10, 2009 On my old Z34 the trunk used to leak at a seam that was halfway down the "rain gutter" between the trunk seal and the quarter panel. I thought the GTP was leaking in the same spot, but I gooped it up with silicone only to discover that it was coming from somewhere closer to the rear window. If mine gets worse I will probably take it to a leak expert. Jamie Check the seams on the roof. On my SE it leaked there and the water ran into the trunk, and also dripped through the rear reading lamps onto the rear seat. I had to remove the small moldings, and re seam-seal them, then put the moldings back in. The long clip strips shattered, so I just put the molding in the sealer to hold it in. Quote Link to comment Share on other sites More sharing options...
carkhz316 Posted March 10, 2009 Report Share Posted March 10, 2009 On my old Z34 the trunk used to leak at a seam that was halfway down the "rain gutter" between the trunk seal and the quarter panel. X2, but on my euro Quote Link to comment Share on other sites More sharing options...
Andrew Posted March 10, 2009 Report Share Posted March 10, 2009 rear windshield seal. Quote Link to comment Share on other sites More sharing options...
mfewtrail Posted March 10, 2009 Report Share Posted March 10, 2009 Where the tails mount is a common area that lets water in. They have those rubber bushings inside the nuts on the mounting studs that usually disintegrate over the years. Quote Link to comment Share on other sites More sharing options...
SigEpCutlass Posted March 10, 2009 Report Share Posted March 10, 2009 My cutlass had a leak near the rear window I had to repair. It wasn't that bad to fix I just needed some silicone. Quote Link to comment Share on other sites More sharing options...
Garrett Powered Posted March 11, 2009 Report Share Posted March 11, 2009 every car I seen has leaking taillights. I degrease them really good and silicone the gaskets and then you might still have more leaks like mentioned. Quote Link to comment Share on other sites More sharing options...
5speedz34 Posted March 11, 2009 Report Share Posted March 11, 2009 It's poured here a ton over the past few days and I have a good 1/2" of standing water in my spare tire well. Quote Link to comment Share on other sites More sharing options...
CSI_MuNkY Posted March 11, 2009 Report Share Posted March 11, 2009 I drilled a 1/8" hole in the bottom of my spare tire well after having to chip my spare tire jack out of a 6" block of ice on the side of the road Jamie Quote Link to comment Share on other sites More sharing options...
5speedz34 Posted March 11, 2009 Report Share Posted March 11, 2009 Ya I think over break I'm going to drill a hole. I have no spare tire in at the moment, just a loose crosslace. My rear tailights, at least the drivers side, one of the studs is broken and just keeps spinning. Spring can't get here any sooner. I also have a leak along the passenger side c-pillar that is leaking into the car. Quote Link to comment Share on other sites More sharing options...
CSI_MuNkY Posted March 11, 2009 Report Share Posted March 11, 2009 Spring can't get here any sooner. Isn't that the truth!! So much to do!! Jamie Quote Link to comment Share on other sites More sharing options...
5speedz34 Posted March 11, 2009 Report Share Posted March 11, 2009 It's finally get nice here. Next week is spring break for me I'm hoping to do a few odds and ends. Quote Link to comment Share on other sites More sharing options...
Skunkworks_Zed Posted March 12, 2009 Report Share Posted March 12, 2009 Ya I think over break I'm going to drill a hole. I have no spare tire in at the moment, just a loose crosslace. My rear tailights, at least the drivers side, one of the studs is broken and just keeps spinning. Spring can't get here any sooner. I also have a leak along the passenger side c-pillar that is leaking into the car. Check the seams on the roof. On my SE it leaked there and the water ran into the trunk, and also dripped through the rear reading lamps onto the rear seat. I had to remove the small moldings, and re seam-seal them, then put the moldings back in. The long clip strips shattered, so I just put the molding in the sealer to hold it in. Also, why drill a hole in the trunk (which WILL rust)? Just bend the tab on the plug, and tap it up a bit with a hammer. All the water will come out, then reseat the plug, bend the tab back, and done. Until I get the leaks fixed on my GTP, I just leave the plug open a tiny bit so the water won't accumulate. No water, bugs, mud, etc. will come through the opening unless you leave a massive gap. Quote Link to comment Share on other sites More sharing options...
5speedz34 Posted March 13, 2009 Report Share Posted March 13, 2009 When you say small moldings do you mean those painted stick on things that go on the roof? Quote Link to comment Share on other sites More sharing options...
Skunkworks_Zed Posted March 14, 2009 Report Share Posted March 14, 2009 Yep, the small ones right above the quarter/sail panel. A good way to see if they are leaking, is to remove the c-pillar panels, and look at the seam near the roof. I pulled them off my GTP today, and I can see its been leaking there (tiny bit of rust starting on the seam, and visible dirt marks) Quote Link to comment Share on other sites More sharing options...
CSI_MuNkY Posted March 14, 2009 Report Share Posted March 14, 2009 When I drilled the hole I also sealed the metal with a rust inhibiting paint... so... no rust! Jamie Quote Link to comment Share on other sites More sharing options...
5speedz34 Posted March 14, 2009 Report Share Posted March 14, 2009 Yep, the small ones right above the quarter/sail panel. A good way to see if they are leaking, is to remove the c-pillar panels, and look at the seam near the roof. I pulled them off my GTP today, and I can see its been leaking there (tiny bit of rust starting on the seam, and visible dirt marks) My interior is in pieces and if it rains I can see water dripping through the holes in the c-pillar. I didn't know it was right underneath those seals. Quote Link to comment Share on other sites More sharing options...
