In this post @RobertISaar can't remember what the other black pad is for on the white resistor IC, but at least he has not seen them causing issues.
Gotcha.
Unfortunately, due to shipping costs and taxes it does not make much financial sense to get anything fixed across the Atlantic.
I was thinking that if this is a remanufactured unit, maybe they would be willing to repair yours at a reasonable price.
jiggity76 reacted to a post in a topic: 89 GP SE Instrument cluster repair 25122113
@jiggity76, a remanufactured cluster would be a solution, after some odometer transplantation work to keep the mileage of course. I assume that a remanufactured one will also have just a resistor added in order to replace the faulty one between pin 4 and 10 on the infamous white resistor IC (I do not think any 100% accurate original ones still exist). I should maybe ask the Ebay seller if they indeed fix them like that, if it's not to much of a trade secret. As said in my initial post, I live in Europe, so by the time all transport and taxes are paid, a replacement cluster is quite expensive, knowing that repairing my cluster is possible with some soldering work and a 1$ resistor. So that seems to be the best option in case a neat & quick solution is not available (like a replacement for the white resistor IC as Batee makes for Corvettes, or a circuit board as can be found for many other models on https://www.cajuntachshop.com/ ). So I'll try to do that fix, many others on the internet did just that with success. But I remain curious about the effect of degradation of the other black field on the white resistor IC and any documentation would be welcome, I only have the service manual of the car.
94 olds vert reacted to a post in a topic: 89 GP SE Instrument cluster repair 25122113
I enjoyed reading your thread here but I must admit that I'm a moron when it comes to electronics. You might as well be speaking Japanese to me. It's not your fault of course, it's definitely mine. Typing in that number on Ebay, this cluster along with 2 others popped up. This one though is a remanufactured unit. Maybe they is a solution thru this place? https://www.ebay.com/itm/124970672582?epid=26044439203&itmmeta=01HY9CCXBWVEKDBMQQ8P48BCGR&hash=item1d18d521c6:g:XMcAAOSwXvphdbou&itmprp=enc%3AAQAJAAAA4FvtXGhD3ynH%2FUR99gvrGyqpTrQlhnDyASk4eK4%2Fca4OOv6UKXx8PdOAyy%2FJXd3WMC0hivWON5tM5qLEs1dWmPx1EZ93EfcAB%2F%2BzJ5eZEvpxetPo6IIUMG9MT8OPMPQIcO%2BjpkzL%2FaQUte7afW4dnVEX7u%2B98Fy0mu75s5zL%2FRRVZAjq02LztCqfEyXJT09vgK%2BUnLtDo6NivgaICJxkRsB%2Fiy4y%2BwWsfIEQ4oIvDKd1qHxaifOZrp8N7VtlfiBc0bs8chKKpuww9TKZKQRFgUXj4X%2BTx%2FyCYrTQXudxf8%2B4|tkp%3ABk9SR_zVs6zyYw
It seems there are currently no solutions available for the resistor chip or the tacho circuit board for this specific instrument panel; other than bypassing pin 4 and 10 with a trimmer potentiometer in order to be able to obtain the correct resistance again. On all similar fixes, nobody seems to mention the other film resistor, in this case between pin 3 and 13. Eventually that one will also rise to infinite resistance, which should have some undesired effect, but I do not know it's purpose. If someone would have any schematic of instrument panel 25122113, feel free to post it!
Yes it’s getting expensive already. It did sit for a long time so I didn’t mind putting some newer parts on it. I would guess it was all original stuff on it. But anyway I ordered an ecm. I’ve addressed all of the codes it was throwing and 21,43,53 keep coming back. New iac, new knock sensor, new alternator. Still high voltage errors. Sounds like there is an internal voltage regulator in the ecm that can go bad. I tried cleaning the ecm connectors and no change. Runs nice until the ecm takes over then the codes pop up and runs erratic again. I will update after install.
Selenoyl started following To anyone that did a UB3 swap/replacement and Instrument Panel lights out & more- 1994 Cutlass Supreme
Try not to give into the habit of *throwing money at the problem*. Purchasing unnecessary part is a waste of money........ The code 43 may not necessarily be the knock sensor itself but an issue with the harness or possibly the ECM. Seeing as you have the code 53 (system overvoltage) if you know beyond a doubt that the alternators regulated output is approx 14.2 when the engine is running then the ECM could be the source of the issue.
well if I can get a few more years out of it then its worth $250 to me. It had new tires, front wheel bearings, tie rods, and ball joints before the motor blew up. Intake gaskets were also done a few weeks prior. Trans shifts perfect the ta mount doesn't seem like its structurally compromised at all as Ive hit lots of potholes with it and the ball joints went out before the TA mount did lol. If I cut out around that rust hole could I get a little plate of steel and pop rivet it in to buy me a little more time? that's the only rusty part on the whole mount, or could I pull up the carpet and pop rivet into the mount from the top to keep it secured to the floorpan?
I mean its like any corrosion related failure, its good till its not. Can't actually say it might be good till you hit a pothole wrong and then its game over. Might go 2 years might go 2 weeks.
Other side is perfect i tested it with a hammer. I also tested the one in tge pictures and it was solid everywhere outside of that little hole. It held a jack.. how bad do these get before they fail? I dont want to junk it bc the floors and fuel/brake lines are perfect
Listen, i'm an idiot. I'm presently putting a new transmission in my 375k daily driver. If the underside looked like that I wouldn't be. Anything is fixable, but that's a pretty complex area and a critical one at that. I can see that the rocker and quarter is made of thin air and the metal around the mount isn't that much better. I know used car prices are out to lunch not but not sure I would put the effort in based on what you're telling us. Then again if you've already bought the engine do the minimum to get the car up and running and scrap it after it finishes breaking.
They ain't making those cars any more. Maybe you can weld-in a repair? And verify the other side, too.
Im putting a $250 junkyard motor in my prix and wondering if its worth it with this rust or should i just junk it. Reason it looks muddy is because i put fluid film on it last fall
Hey guys, not sure if I’m replying correctly to these. First things first. Nice engine! Next, thank you for the schematic… Lastly I’m down to code 43 and 53. Knock sensor is new. It’s not running properly. Is smoother now but am curious if you guys have the magic fix? Thanks again for all the helpful information. I got some dielectric grease and electric cleaner. I noticed gm had a bulletin to clean and grease the wiring harness connector. I assume to the ecm. Probably should do all the connector’s I can get to. Could be bad ecm if it doesn’t help. the fan kicks on at weird time’s also. Something electrical is not letting it run right. High idle still also. Iac new.
Stock 89 audio system common issue repair and weird FM tuning issue
89SE replied to 89SE's topic in Car Audio
Update: I found out that the issue of being limited to 104.05MHz is probably how it is supposed to be, at least for European versions. This German article ( http://www.fieros.de/de/articles/radio.html ) describes that a diode can be put in a Fiero radio to enable steps of 50kHz, instead of the 200kHz in the USA version (uneven multiples of 100kHz). In Europe, steps of 100kHz are used, 50kHz maybe exceptionally in Italy, so the modification makes sense. But this modification also limits the receiver from 87.5 to 104.05MHz. Since European frequencies go up to 108MHz, it is rather strange that it was deemed sufficient to receive only about 60% of all radio stations...- 1 reply
- grand prix
- radio
(and 1 more)
Tagged with:
I also have that Kent-Moore kit and it's so handy. For the 91-93 LQ1's, the cam cog puller is a must as well. Starting in 94, GM switched to a lock washer and bolt system that doesn't require this tool. Both of my LQ1's are within that 91-93 year range. This tool right here, this puller, is an absolute blessing! After my local GM dealer said my original motor had a timing issue...and I knew the belt was good and timed correctly, I assumed it was the timing chain. This is a puller for the timing chain and sprockets. The chain and sprockets have to be pulled as one unit due to how they're designed like most timing chain systems. Because of the tight tolerances between the dampener/nose of the crankshaft and right side frame rail, a conventional puller to my knowledge won't fit in that area. I even rented the smallest puller they had a my local parts store and it was still way to big to even try and lock onto the sprockets. I found this bridge puller I think it's called years ago on Ebay. SO GLAD I BOUGHT IT!!!! The GM dealer wanted to either drop the engine cradle on the passenger side or if need be, drop the entire cradle and drivetrain out of my Olds International Cutlass for the repair. Total bill was going to be estimated between $5500-6500. This bridge puller allowed me to do the job myself and only costing me about $100 bucks. This includes the price of the puller, the chain/sprockets, and the guides. This kit also included the tool to drive the crankshaft sprocket and dampener back onto the crankshaft. The repair process and bridge puller being used. You can see the tight tolerances of where this tool needs to work and how beautifully it all fit together. Again, this specialty tool saved me THOUSANDS of dollars! New timing set in place.
That's what the mechanic said. It was a very easy fix because everything was relatively easy to access. I have no idea about special tools; I just knew that repair was above my pay grade.
How many special tools have you had to aquire? I bought a Kent-Moore GM 3.4 DOHC tool kit off of EBay years ago, but haven't looked in a while to see what is available anymore.
I'm probably alone in this but I feel the LQ1 isn't that hard to work on. Granted, they do require special tools but like anything mechanical, the right tools for the job helps tremendously. The water pump is very easy to get at in particular. Right there out in the open.
Human started following New Water Pump for the '95 Vert
So, a few weeks ago, I was driving my '95 Cutlass Supreme convertible over to a friend's house, and the car started running a little hot, not overheating, but hotter than I was comfortable with. When I got back home, I looked under the hood, the overflow jug was empty and things were quite wet down by the water pump. It was right at the end of the spring semester, so I just didn't have time to mess with it, beyond pouring in a gallon of antifreeze until today, when I sent it over to my mechanic's shop, and amazingly, he had a water pump for it sitting on the shelf, had the whole thing done in less than four hours. That just never happens. Even better, it was a comparatively inexpensive repair. He was a little afraid there might have been head gasket damage, but everything checked out okay in the end. The best part was the repair was a bit less expensive than I expected. He ballparked it at around $280-$400, and it came in at $281 and change. I'm stoked that I don't have to miss anymore prime convertible weather.
that’s totally fair. And I totally get the desire and challenge and that being worth it alone!! Not sure I’ll tackle it but I think it’s awesome it can be done and with the 5 speed too!
An "OBD2 scanner" doesn't work on a '95, because '95 is not OBD2. Therefore, you'd need a scan tool compatible with what is now known as "OBD1". They tend to be more expensive, and need a different adapter/connector for every brand of vehicle since there's dozens of proprietary connector bodies on the vehicles. Every manufacturer used a different style of connnector. GM alone had several depending on application. A decent scan tool will work with GM products from 1980 1/2, onward to the limit of their software--often post-2000, perhaps all the way to 2024. Mine goes up to 2007, but since I don't own a vehicle newer than 2003, I'm all set.
EXACTLY the same way you'd connect to any other vehicle with a diagnostic connector. '95 is no different in that regard. Find a compatible scan tool, use the correct adapter, connect it to the diagnostic connector. You may need to supply "12 volt" power to the scan tool via a cigarette-lighter power adapter or similar. Follow the instructions for the scan tool to type in the VIN number or whatever it takes to make the tool "talk" to the on-board computer. Guys get all weird about pre-OBD2 vehicles and scan tools. No need. Just use a DECENT scan tool, and it'll work out just fine. If you use a craptastic "code reader", or some consumer-grade bottom-feeder junk tool, you can expect it to be useless or worse, problematic.
