It’s been just a little over a year now since I got the Regal…so what better way to celebrate that than with some more recent pictures. Nothing much visually has changed except for the refinished wheels and new tires…which was a fairly large, yet subtle change on its own. My intent is to keep the car as stock as possible, and to keep it up to snuff mechanically to be used as a reliable, fair weather cruiser. And to shake things up…. This is the final picture I ever took of my 89 GS before it was parked for good in summer of 2008. -
primergray reacted to a post in a topic: New (returning former) member with a new to me 1st gen survivor
245/50R16
Actually its been holding up great. I've got over 20k miles on the swap now over 2 years. Nothing major, a couple ripped cv boots which may be because they were junkyard sourced. I highly recommend adding a HTOB spacer. ZZP sells them for around $50. Sits behind the HTOB and moves it closer to the clutch by 1/4" for earlier engagement and longer life. Aside from engineering the trans mount, the hardest part is getting the clutch pedal mounted and situated. The pedal arm needs to be cut & welded into proper position as well. As far as the mount, the low-profile mount I fabbed up works great. Only modification I made was adding rubber bushings under the nuts at the bottom to further insulate the mount from the frame. On an aluminum subframe, it might have to be done a bit different. Might be able to drill two holes and bolt it in the same way, but I haven't been hands-on with an 04+ subframe so I can't say for sure. I'm not a fan of the modified 4T65E bracket method that requires tubular control arms as the mount sits outside the frame. An extra $650 that could be spent elsewhere. There really are half a dozen ways you could fab up a mount but I can say for sure the one I made does the job. 3/16 steel plate holds up well so far. I have also just finished taking the time to document the changes to the tune that are highly recommended for a manual swap: Idle speeds in-gear changed to match P/N as its going to be wired to be in D at all times now. ( I actually added a toggle switch to change between forcing it in D or P, since P is needed for a crank relearn procedure if you need it) DTC codes changed And finally zeroing out all the auto trans stuff:
Psych0matt replied to Black92GS's topic in New Member Introductions
Welcome (back)! somehow I never got out for long, but the last few years I haven't posted as much, been trying to check in more often -
Psych0matt replied to DaleCar_3's topic in New Member Introductions
I know I;m a bit late but do you have a sound clip? I'm happy with my setup but it still doesn't sound great, I've never heard an LQ1 sound great haha -
Chase?
MrMcTiller replied to GtpKo's topic in Powertrain
Awesome writeup! How's the 5 speed holding up? I've been wanting to do this swap in my 2004 Impala LS. Do you have any advice/recommendations for making the f23 mount? I have the aluminum subframe. Would it be the same mounting as yours? -
MrMcTiller joined the community
55trucker started following 1992 Grand Prix aftermarket suspension
gr_elvis started following 93 Cutlass Supreme convertible top issue
Why won't my top go all the way down on one side?
lenexakid joined the community
92Lumi started following LQ1 3.4L DOHC V6 Timing Belt Change
55trucker started following Need to know some info about replacing the strut cartridge? , Convertible Dome Light Switches and Wheel fit
GnatGoSplat replied to j_mezz's topic in Cutlass Supreme Convertible
He hasn't logged in since last Dec, but there's a way to use more commonly available SPST switches. I had a writeup on that which is no longer online, but I could post if that'd be helpful. -
suburbanjack joined the community
I have a similar *Powerbuilt* kit. -
90% of the time the only special tool I use is the spanner nut tool that actually unscrews it from the cartridge. Like I said I've had it where as soon as you pull the upper mount the strut rod wants to go hard to one side or the other thats where this tool, circled comes in to help stabilize it while you work.. also obviously make sure you're on level ground. then you jam the spanner tool down over it and spin it out pull the strut cartridge, slam the new one in and tighten it back down. -
MickS77 joined the community
this is one suppliers kit. https://westerntool.com.au/wp-content/uploads/AT185.jpg -
