  2. Today
  3. It’s been just a little over a year now since I got the Regal…so what better way to celebrate that than with some more recent pictures. Nothing much visually has changed except for the refinished wheels and new tires…which was a fairly large, yet subtle change on its own. My intent is to keep the car as stock as possible, and to keep it up to snuff mechanically to be used as a reliable, fair weather cruiser. And to shake things up…. This is the final picture I ever took of my 89 GS before it was parked for good in summer of 2008.
  4. Yesterday
  5. 55trucker
  6. ColesM92GTP
    245/50R16
  7. Actually its been holding up great. I've got over 20k miles on the swap now over 2 years. Nothing major, a couple ripped cv boots which may be because they were junkyard sourced. I highly recommend adding a HTOB spacer. ZZP sells them for around $50. Sits behind the HTOB and moves it closer to the clutch by 1/4" for earlier engagement and longer life. Aside from engineering the trans mount, the hardest part is getting the clutch pedal mounted and situated. The pedal arm needs to be cut & welded into proper position as well. As far as the mount, the low-profile mount I fabbed up works great. Only modification I made was adding rubber bushings under the nuts at the bottom to further insulate the mount from the frame. On an aluminum subframe, it might have to be done a bit different. Might be able to drill two holes and bolt it in the same way, but I haven't been hands-on with an 04+ subframe so I can't say for sure. I'm not a fan of the modified 4T65E bracket method that requires tubular control arms as the mount sits outside the frame. An extra $650 that could be spent elsewhere. There really are half a dozen ways you could fab up a mount but I can say for sure the one I made does the job. 3/16 steel plate holds up well so far. I have also just finished taking the time to document the changes to the tune that are highly recommended for a manual swap: Idle speeds in-gear changed to match P/N as its going to be wired to be in D at all times now. ( I actually added a toggle switch to change between forcing it in D or P, since P is needed for a crank relearn procedure if you need it) DTC codes changed And finally zeroing out all the auto trans stuff:
  8. Last week
  9. Psych0matt
    97cutty
    hi
  10. Welcome (back)! somehow I never got out for long, but the last few years I haven't posted as much, been trying to check in more often
  11. Psych0matt
    New member from WI
  12. Psych0matt
    I know I;m a bit late but do you have a sound clip? I'm happy with my setup but it still doesn't sound great, I've never heard an LQ1 sound great haha
  13. Psych0matt
    My Turbo 99 Z34 Monte Carlo
    Chase?
  14. MrMcTiller
    Awesome writeup! How's the 5 speed holding up? I've been wanting to do this swap in my 2004 Impala LS. Do you have any advice/recommendations for making the f23 mount? I have the aluminum subframe. Would it be the same mounting as yours?
  15. 55trucker
  16. ColesM92GTP
  17. Why won't my top go all the way down on one side?
  18. SuperBuick
  19. GnatGoSplat
  20. Earlier
  21. pwmin
    Wheel fit
  22. 55trucker
    Wheel fit
  23. Taz1959
    Wheel fit
  24. 55trucker
    Wheel fit
  25. pwmin
    Wheel fit
  26. I have a similar *Powerbuilt* kit.
  27. 90% of the time the only special tool I use is the spanner nut tool that actually unscrews it from the cartridge. Like I said I've had it where as soon as you pull the upper mount the strut rod wants to go hard to one side or the other thats where this tool, circled comes in to help stabilize it while you work.. also obviously make sure you're on level ground. then you jam the spanner tool down over it and spin it out pull the strut cartridge, slam the new one in and tighten it back down.
  28. this is one suppliers kit. https://westerntool.com.au/wp-content/uploads/AT185.jpg
  29. Thank you definitely with keep you posted when I do again. I am going to get the tool again. I sent it back because I couldn’t use it but I’ll be getting another kit.
  30. I have a 97 Chevy Lumina LS with 16" aluminum wheels a guy has 1999 Pontiac GT 16" wheels for sale can I put them on without any problems I made the mistake of buying 4 wheels from a Pontiac Grand Prix from 2002 and found out the wheels hit the front calipers. Tire man said to get them on I needed spacers which I think would be dangerous. My brother said threads are not gonna reach bolts to snug with spacer on.
