primergray reacted to a post in a topic: Luminac
Turbocharged3800 reacted to a post in a topic: Luminac
Turbocharged3800 reacted to a post in a topic: Mystery Caliper Bracket
This aged well;)
55trucker started following Luminac
primergray started following Which Turbo GP stays and which goes.
Lukeperrin07 replied to GtpKo's topic in Powertrain
What other modifications did you have to make to the tune? Any fueling/timing sorta things? -
GnatGoSplat started following Which Turbo GP stays and which goes. and What Conditioner Are You Using on Your Convertible Top Seals?
GnatGoSplat replied to kcac's topic in Cutlass Supreme Convertible
I always used Permatex Die-electric Grease, which is just a silicone grease. I'm guessing whoever used Gummi Pflege doesn't frequent the forum any more. Sounds promising. Couldn't find any actual tests or comparisons. This was the closest thing I could find to a test: https://www.bimmerforums.com/forum/showthread.php?1687676-Annoying-Door-Creaks-Gummi-Pflege-Test -
Jiggity getting a turbo first gen?!?!
Just my $.02....The one you enjoy driving the most is the one you keep. There is something to be said about a mechanically sorted, but less than visually perfect vehicle that you can simply jump in and drive without worry. As much as I hate to say it, any 1st Gen W that isn't a total beater is relatively rare these days. Individual rarities within that are almost irrelevant when it comes to market value of these cars and I would go for the colour combo I like better, rather than the rarer combo every single time.
Both are pretty clean underneath. Not Southern California clean but pretty good - I have no concerns about their integrity. Obviously the black one isn't looking as hot now that it sat out side for a time. It likely won't be available till next spring at soonest as its in the very back of a pole barn and given that its October its probably well blocked in by other cars for winter storage by now. If you're interested PM me and we can take it from there. I have all sorts of parts that could be included including an engine. Its for sure not drivable without completely flushing the fuel out at minimum.
Ok, is the underside ok? How much would you want for the Black one?
Just the red one. Black is still PM3. If I keep it It will be getting converted before I drive it far.
That's a very cool pic. Did you say the ABS has been converted on both cars?
that cloth or leather?
rcLord510 started following Which Turbo GP stays and which goes.
I'll have to find some pictures. Best ones I have are from 10+ years ago when the black one was in far better shape. Long story short, engine blew up, it sat outside. Then I ended up with it and moved it to indoor storage but the time outside had already taken its toll. Right now its very dusty and sad looking and buried in the back of storage so its hard to even see it right now. Last couple weeks I've been daily driving my red one. Made me realize how much I've missed the turbo cars. I think technically speaking red/gray was the most rare color combo. If you'd have asked me years ago I'd have been on board with the gray interior all day long. Now I think the tan works with the gold wheels and badging. I'm torn because the chassis of the black car IS that much better. But I've put insane amounts of work into making the red one as good as it presently is. Not sure if rarity of the color combos really moves me like it would used to. Maybe I can use that to my advantage to get more money out of the black one. Some guy on FB wanted to buy both but wanted to pay a very small sum for them. I dono I think they tend to wear arrest me red better then black. I think whatever happens the sale of one and a bunch of parts will fund the restore of the other. I'm still very much torn as the black one when it was running really drove fantastically. I'm just rambling at this point.
With his Black car, I've only seen 4 with Gray interior. One of the 4 was a red car. This is 1 of the 4 gray interior cars. It was about an hour South of me at a private yard. It still might be there. Makes me incredibly sad.
