Amanita reacted to a post in a topic:
Getrag 282 info
GarrettLowell reacted to a post in a topic:
New to this place. Hello.
GarrettLowell joined the community - Yesterday
IMG_4560.MOV -
Thanks. I should have worded that better. The 1227730 is not confirmed. I only listed it because I found TunerPro definitions that referenced the 1227727/1227730 family. I haven't physically verified the ECM service number yet. Before I pull the ECM, can someone confirm the factory ECM service number and MEM-CAL for a stock 1990 Cutlass Supreme 3.1 LH0 W-body? Also If the factory ECM is 1227727, which TunerPro ADX and XDF are you using for a stock 1990 LH0?
