90sEraWhips started following 3400
i have the rubber connector for the vaccum harness from my 89 2.8 v6 corsica, i’m looking for new hard lines for the vacuum harness now, one of mine has a hole, i can buy the lines if you still have them since you’re going with softer ones, maybe we can trade parts -
babyteef joined the community
torinstone joined the community
That's a daunting swap! Wish I had the balls to do it, but I draw the line at cutting away at a unibody frame that likely wouldn't have won any 1995 IIHS safety awards in the first place. You're all good BCM-wise, there isn't one. -
GnatGoSplat started following Radio replacement for a 1994 Cutlass Supreme Convertible and 1993 Cutlass convertible top not moving, down or up
Yep, I've probably removed the bezel a hundred times across 3 Cutlass Supremes and it's never broken. It's hard plastic and seems brittle, but it's actually quite durable. - Earlier
Cojack87 joined the community
Jakey joined the community
