  2. kcac
  3. Yesterday
  4. Adding some pictures because it is a very rare and very fascinating setup. Lots of pics of the engine bay exist, but Ive never found any of the engine assembly on the subframe. Enjoy!
  5. Last week
  6. 55trucker
  7. bama223
  8. Holy Hell...how did I miss this!!!! This is pretty incredible and so glad I finally found this thread. I am here for any help.
  9. The access cover on the shock tower side, you will have to remove the ECM & then you'll see the access cover. Can't tell you for sure but the mem-cal will could very well be the AUMY, pull the ecm, remove the cover & you'll see for sure.
  10. Thank you for pointing me to the correct location. I found the ECM under the passenger-side strut tower. I uploaded three photos of it. The only label I can see is the Delphi remanufactured sticker (SVC #16198260). I don't see an obvious inspection cover or small access panel for the MEM-CAL. Before I start removing mounting bolts or unplugging connectors, can you tell me exactly which fasteners need to come off to access the MEM-CAL and read the original GM ECM service number? I don't want to damage anything or take apart more than necessary.
  11. Thanks, that's exactly the information I was looking for. I haven't physically verified my ECM yet. I'll check the passenger-side shock tower under the hood and report back with the ECM service number and MEM-CAL ID. Since my car is a 1990 Cutlass Supreme 3.1 LH0 with an automatic, can you tell me which stock MEM-CAL ID I should expect to find?
  12. You understand that because you're dealing OBD1 the ECM mem cal's are tuned to the specific vehicle powertrain the mem-cal is plugged into for particular vehicles ECM. If one is attempting to do custom chip mods you can't just use a program such as TunerPro to alter the mem-cal, you have to burn a new eeprom blank chip (27C256) to fit into the chip housing that plugs into the mem-cal slot. To burn the chip you will need the physical Moates chip burner, a laptop with the Moates software on it to read the existing mem-cal, extract that BIn file, then you have to write the new BIN program with the Moates software & then command the burn of the new blank chip. To be honest one usually doesn't get it right the 1st time. Here is the list of GM OBD1 ECMs & the accompanying MEM-CAL ID's. Yours will the 1227727. Your engine code is *T*, the mem-cal will be for either auto or man trans. Your mem-cal has a sticker attached to the mem-cal, pull the ECM inspection cover, the mem-cal is right below the cover for easy access. The ECM is easy to recognize, open the hood, in front of right side shock tower under the plastic cover, bolted to the shock tower. https://pcmhacking.net/ludis/p4xref.html#1227727
  13. Thanks. I should have worded that better. The 1227730 is not confirmed. I only listed it because I found TunerPro definitions that referenced the 1227727/1227730 family. I haven't physically verified the ECM service number yet. Before I pull the ECM, can someone confirm the factory ECM service number and MEM-CAL for a stock 1990 Cutlass Supreme 3.1 LH0 W-body? Also If the factory ECM is 1227727, which TunerPro ADX and XDF are you using for a stock 1990 LH0?
  14. Earlier
  15. Raffaelli
  16. Do I have the correct dipstick for a 1995 Oldsmobile Cutlass Supreme with the 3.4l DOHC engine? Photos below. The owner's manual states 5.5 quarts of oil when doing an oil and filter change. I change the oil and filter, run the engine for a few minutes, let it sit for about 5 or 10 minutes, then check the dipstick and it shows the oil between the high and low marks.
  17. Where'd you get a *730* ecm from? That's an all metal cased unit, it was not put into the W body cars. There's no way to mount it at all. The proper ecm for your car would be the 1227727 ecm. Seeing as you have the incorrect ecm you more than likely do not have the correct memcal chip as well.
  18. Can someone with a stock 1990 LH0 W-body tell me exactly which ADX/XDF/BIN combination they're using with TunerPro RT? Also does anyone know the factory procedure for setting the throttle stop screw on a 1990 LH0 throttle body? Mine was previously adjusted, and I'm trying to return it to the correct baseline without guessing. Sorry, forgot to ask the most important questions in the post. 1990 W-body LH0 3.1 MPFI 1227730 ECM (not confirmed); thanked the Lord it wasn't a snake. 8192 baud ALDL Speed-density system
  19. I have a 1990 Oldsmobile Cutlass Supreme W-body with the 3.1L LH0 and automatic (4T60). I'm using an ALDL cable with TunerPro RT to diagnose a no-idle condition. I'm trying to verify that I'm using the correct acquisition definition and calibration before I rely on the live data. Can anyone confirm: Which ECM service number and mask should this car use? Which ADX (or ADS) is the correct one for a 1990 LH0 W-body? Which XDF and stock BIN correspond to that ECM? Is A109 correct, or is there a better definition for this application? Has anyone successfully scanned a 1990 LH0 with TunerPro RT, and if so, what files were you using? Current symptoms: Fuel pressure is 38–40 PSI. Engine will run smoothly if I keep it alive with the throttle. It will not establish an idle on its own. Code 34 has appeared. Code 34 Cleared. MAP values appear reasonable (while running), but some other parameters don't seem to decode correctly. I have already verified ignition wire routing and corrected several vacuum hose issues. I'm trying to verify my scan data before replacing any more parts. Dashboards 2026-07-12 16-05-16.mp4 Dashboards 2026-07-10 19-48-52.mp4
  20. Jscott
  21. 55trucker
  22. So I bought an old Matco 4000e scanner. Came with a pathfinder 2 cartridge and just a ford cable. I want to locate or make a harness for that to fit a GM obd1. The unit has a db25 male connection on it. But it also needs to be powered up too… any ideas would be a great help. Thanks.
  23. sadolboy48
    89 olds swaybar
  24. 55trucker
    89 olds swaybar
  25. sadolboy48
    89 olds swaybar
  26. 55trucker
    89 olds swaybar
  27. sadolboy48
    89 olds swaybar
  28. Psych0matt
  29. rich_e777
    89 olds swaybar
