GnatGoSplat started following Does anyone have any vacuum harness from any 2.8 V-6 or 3.1 V6?
Dorman does sell universal hard vacuum tubing. You can probably bend it to shape with a heat gun. Years ago, I just put heatshrink tubing over the cracks. Looked like an obvious fudge-fix, but worked fine. - Yesterday
90sEraWhips started following 3400
i have the rubber connector for the vaccum harness from my 89 2.8 v6 corsica, i’m looking for new hard lines for the vacuum harness now, one of mine has a hole, i can buy the lines if you still have them since you’re going with softer ones, maybe we can trade parts -
babyteef joined the community
torinstone joined the community
That's a daunting swap! Wish I had the balls to do it, but I draw the line at cutting away at a unibody frame that likely wouldn't have won any 1995 IIHS safety awards in the first place. You're all good BCM-wise, there isn't one. -
GnatGoSplat started following Radio replacement for a 1994 Cutlass Supreme Convertible and 1993 Cutlass convertible top not moving, down or up
Yep, I've probably removed the bezel a hundred times across 3 Cutlass Supremes and it's never broken. It's hard plastic and seems brittle, but it's actually quite durable. - Earlier
Cojack87 joined the community
Jakey joined the community
The blocks are without the rubber and just help in place by the spring tension. After liberal use of Lucas red and sticky on the blocks the noise has stopped. It has been about a week now so I'm hopeful this issue is solved. Thank you all for the reply and info
