Aceknox23 Posted June 3 Report Posted June 3 Hi, I have a 92 Chevy Lumina Z34 automatic with the V6 DOHC. It's all stock. I am new to fixing cars and got it a year ago. Any tips or suggestions is appreciated. The current thing I'm working on it wiring and brakes. pwmin, rich_e777, 94 olds vert and 1 other 3 1 Quote
94 olds vert Posted June 3 Report Posted June 3 Welcome to the site! There is plenty of information to find around here about these cars. Quote
55trucker Posted June 4 Report Posted June 4 Nice car...1st thing you might consider is removing that led light bar right in the centre of the path for the air intake for the a/c condenser & the rad. rich_e777 1 Quote
94 olds vert Posted June 4 Report Posted June 4 45 minutes ago, 55trucker said: Nice car...1st thing you might consider is removing that led light bar right in the centre of the path for the air intake for the a/c condenser & the rad. I thought the same thing, but then I saw the valance is intact so you know it's fine. primergray, Aceknox23 and Psych0matt 3 Quote
Psych0matt Posted June 5 Report Posted June 5 I'm glad that joke is still funny primergray, 94 olds vert and pwmin 3 Quote
GarrettLowell Posted August 28 Report Posted August 28 Nice to see another Z34 being kept alive. If you’re new to working on cars, I’d focus on getting a solid maintenance baseline before changing anything: fluids, belts, hoses, grounds, and any old or brittle wiring/connectors. Since you’re already into the brakes, I’d check the rubber hoses and hard lines closely too. And if you don’t know when the timing belt was last done on the 3.4 DOHC, that’s definitely something I’d put on the list. Take plenty of photos before unplugging things and tackle one issue at a time. Makes troubleshooting a lot less painful. Psych0matt 1 Quote
calmspindle6 Posted October 3 Report Posted October 3 GarrettLowell said: Nice to see another Z34 being kept alive. If you’re new to working on cars, I’d focus on getting a solid maintenance baseline before changing anything: fluids, belts, hoses, grounds, and any old or brittle wiring/connectors. Since you’re already into the brakes, I’d check the rubber hoses and hard lines closely too. And if you don’t know when the timing belt was last done on the 3.4 DOHC, that’s definitely something I’d put on the list. Take plenty of photos before unplugging things and tackle one issue at a time. Makes troubleshooting a lot less painful. That 3.4 DOHC timing belt is one of those items that can turn a small unknown into a very bad day, so having it on the list early makes sense. Photos of the wiring save so much head-scratching later. Quote
