Q-Ball Posted March 21, 2008 Report Posted March 21, 2008 I've noticed this for a while, when driving around 15 - 20 MPH, my car bounces a little bit. But anything faster its fine. It's had this problem since I got the car. Since than, I got xlaces with new rubber, kyb gr2's. The wheels have been balanced and I have had it aligned, twice. Any idea's? Quote
GOT2B GM Posted March 21, 2008 Report Posted March 21, 2008 Maybe our shitty roads are to blame. Or your tires have flat spots from sitting. Quote
Captain Ficho Posted March 21, 2008 Report Posted March 21, 2008 Maybe our shitty roads are to blame. Or your tires have flat spots from sitting. Shitty roads 99.9%. I have new tires and same thing happens. Fuckin' 401... Quote
Q-Ball Posted March 22, 2008 Author Report Posted March 22, 2008 Well, I got to find a nice smooth stretch of pavement and do a test. Getting sick of replacing all suspension and steering parts here. Quote
EviLette Posted March 24, 2008 Report Posted March 24, 2008 Well, I got to find a nice smooth stretch of pavement and do a test. Getting sick of replacing all suspension and steering parts here. ahahahah I feel ya there. Between the roads and the wind here, I can't tell if my car is still pulling or not. It seems to be drifting... but once again, roads. Good thing I got 3 years of unlimited alignments. Quote
Chancho Posted March 24, 2008 Report Posted March 24, 2008 The suspension on all cars compensates more the faster the speed, therefore if you are driving on the shittyest road on the face of this earth at 200 mph itll be alot better then 5 mph Quote
93CutlassSupreme Posted March 24, 2008 Report Posted March 24, 2008 The suspension on all cars compensates more the faster the speed, therefore if you are driving on the shittyest road on the face of this earth at 200 mph itll be alot better then 5 mph ? Quote
1990lumina Posted March 24, 2008 Report Posted March 24, 2008 The suspension on all cars compensates more the faster the speed, therefore if you are driving on the shittyest road on the face of this earth at 200 mph itll be alot better then 5 mph Within reason I suppose. But if you hit a large hole at 200mph I'm sure you'll have some spectauclar damage Quote
93CutlassSupreme Posted March 24, 2008 Report Posted March 24, 2008 The suspension on all cars compensates more the faster the speed, therefore if you are driving on the shittyest road on the face of this earth at 200 mph itll be alot better then 5 mph Within reason I suppose. But if you hit a large hole at 200mph I'm sure you'll have some spectauclar damage I'd rather hit a huge pothole at 40 instead of 70 or 80. Quote
ns87 Posted March 24, 2008 Report Posted March 24, 2008 I've noticed it with cold temperatures too. In the dead of winter, I thought I was driving a lowered civic without proper shocks. My car "pogo bounced" everywhere. Quote
Chancho Posted March 25, 2008 Report Posted March 25, 2008 The suspension on all cars compensates more the faster the speed, therefore if you are driving on the shittyest road on the face of this earth at 200 mph itll be alot better then 5 mph Within reason I suppose. But if you hit a large hole at 200mph I'm sure you'll have some spectauclar damage The suspension on all cars compensates more the faster the speed, therefore if you are driving on the shittyest road on the face of this earth at 200 mph itll be alot better then 5 mph Within reason I suppose. But if you hit a large hole at 200mph I'm sure you'll have some spectauclar damage I'd rather hit a huge pothole at 40 instead of 70 or 80. Where does it say hitting a pothole, i was just talking about shitty poorly paved roads Quote
95 BLKDOUT Drop Top Posted March 25, 2008 Report Posted March 25, 2008 Its not the roads, mine did the same thing (and still does) so i tested it on a newly paved asfault road and it still did it. its in the rear end and now that i remember i test drove a 93 cutty hard top and it did the same thing. im about to do the coil over conversion, tubular trailing arms and ladder links in a few weeks, ill let u all know if this solves the problem. also try new hub assemblies on the rear, this might solve it also. (mine are original from 95) Quote
ismellrealbad Posted March 25, 2008 Report Posted March 25, 2008 I've noticed it with cold temperatures too. In the dead of winter, I thought I was driving a lowered civic without proper shocks. My car "pogo bounced" everywhere. Roads up by you might have frost heaves. I know maine nh and vermont actually have signs on some roads for it. Its when icy water melts, gets under the pavement, re freezes and causes bumps all in the road. I guess they cant do anything about it and just put signs up. Quote
ns87 Posted March 25, 2008 Report Posted March 25, 2008 I've noticed it with cold temperatures too. In the dead of winter, I thought I was driving a lowered civic without proper shocks. My car "pogo bounced" everywhere. Roads up by you might have frost heaves. I know maine nh and vermont actually have signs on some roads for it. Its when icy water melts, gets under the pavement, re freezes and causes bumps all in the road. I guess they cant do anything about it and just put signs up. Hmm maybe. We didn't get any signs warning us, but either way it went away in warm weather. Quote
93CutlassSupreme Posted March 25, 2008 Report Posted March 25, 2008 I'm sure cold temperatures affect suspensions directly. Rubber bushings can harden in cold temperatures, and shocks/struts could react more slowly to spring movement due to possible thickening of oil inside the shock/strut. Quote
garrenhart Posted 7 hours ago Report Posted 7 hours ago That low-speed bouncing can be tricky to diagnose since most suspension setups react differently at slower speeds. Sometimes, even after new shocks, tires, and alignment, small imperfections in the suspension bushings or worn mounts can create that “bouncy” feeling at 15–20 MPH while disappearing at higher speeds. Checking for uneven tire wear or slightly loose components can help pinpoint it. For anyone learning to manage these subtleties while driving, places like Scuola Guida Keller in Locarno and Bellinzona offer practical guidance on handling vehicles safely under all conditions, which can make noticing and correcting these issues much easier. Routine inspection by a trusted mechanic focusing on suspension links and mounts often resolves the problem, rather than repeatedly swapping tires or shocks. Quote
55trucker Posted 1 hour ago Report Posted 1 hour ago Time to lock the front door.........lol anyone who wants to get in has to answer a skill testing question 1st Quote
94 olds vert Posted 37 minutes ago Report Posted 37 minutes ago (edited) 53 minutes ago, 55trucker said: Time to lock the front door.........lol anyone who wants to get in has to answer a skill testing question 1st Like how much torque should be applied to a lug nut? Or what year did GM release the first w-body? Maybe a much of bunch of questions. Edited 37 minutes ago by 94 olds vert Quote
