Welcome aboard!
Valley94Vert joined the community - Yesterday
Viktor joined the community -
And a spam bot it was.
Kdog joined the community -
was this badge a 88 or maybe 89 year option or standard feature? i've never seen that besides in this video - Earlier
dee joined the community -
amended -
Automatic equipped FE3 springs from a 3.4 DOHC car seem to be the stiffest. The manual trans springs are slightly less stiff (as compared side by side, and they have different part numbers). In other words your automatic Z34 has the stiffest ever available factory.
