Wow this thing is beautiful!!
GnatGoSplat started following Does anyone have any vacuum harness from any 2.8 V-6 or 3.1 V6?
Dorman does sell universal hard vacuum tubing. You can probably bend it to shape with a heat gun. Years ago, I just put heatshrink tubing over the cracks. Looked like an obvious fudge-fix, but worked fine. -
90sEraWhips started following 3400
i have the rubber connector for the vaccum harness from my 89 2.8 v6 corsica, i’m looking for new hard lines for the vacuum harness now, one of mine has a hole, i can buy the lines if you still have them since you’re going with softer ones, maybe we can trade parts -
babyteef joined the community
torinstone joined the community
That's a daunting swap! Wish I had the balls to do it, but I draw the line at cutting away at a unibody frame that likely wouldn't have won any 1995 IIHS safety awards in the first place. You're all good BCM-wise, there isn't one. -
GnatGoSplat started following Radio replacement for a 1994 Cutlass Supreme Convertible and 1993 Cutlass convertible top not moving, down or up
Yep, I've probably removed the bezel a hundred times across 3 Cutlass Supremes and it's never broken. It's hard plastic and seems brittle, but it's actually quite durable. -
That is correct 55...., It has been a bit confusing trying to figure out just the blocks, just the rubber pads, both? To me bother would lift the rest too high and the rubber pads would wear through eventually. I am thinking the blocks will last for a long time, maybe longer the the car, who knows. It has been an interesting experience and I've learned far more about W bodies that I thought I'd ever learn lol. Still curious about actual parts numbers to build the rear coil overs. Thanks for the feedback
