  1. Last week
  2. Jscott
    Rough idle/ volt drop
  3. do i leave it white ,or do i use, the red line ?
  4. fern_anchor
  5. Earlier
  6. willowhammer2
    89 olds swaybar
  7. bluecalais79
    A/C Repair - LQ-1
  8. leafyrook67
  9. brightbuck95
    A/C Repair - LQ-1
  10. bluecalais79
  11. bluecalais79
    A/C Repair - LQ-1
  12. bluecalais79
    OIL LEAK - 1994 Cutlass LQ1
  13. This is a great educational video about these motors. You can skip forward to the appropriate section for any questions.
  14. Agreeing with 55 here. Those are reusable...I can send you a video of the process.
  15. Red Menace
    Want to buy
  16. That item is no longer produced, finding a *new* replacement will be on the awkward side. They can be serviced, it's just a mechanical oil filled/spring loaded tensioner.
  17. do you know were i can found the timing belt tensioner for this car the motor is 3.4 lq1 am changing the timing belt but mine is crying oil i need a new on the part number is GM 24503860
  18. It's dusty........but not rusty. Nice climate in Peru.
  19. That's awesome, I often wish my Cutlass could end up somewhere exotic and I could live vicariously through it.
  20. GnatGoSplat
  21. 4doors4flying
  22. Yep, that tracks. The 7727/7730 confusion trips up a lot of people because the guts and calibration family overlap, but the packaging and mounting are what matter in the W-body. For CuttyBawl’s case I’d still verify the MEM-CAL broadcast code before trusting any ADX/XDF combo, especially with a reman ECM sticker involved. For scanning only, the right data stream/mask matters more than the XDF, so if it’s truly a 1990 LH0 he should be looking at $88 stuff first, not just grabbing A109 because it “sort of connects.” For tuning, yeah, starting from $A1 makes sense if you know what you’re changing, but I wouldn’t send a first-timer down that rabbit hole until the idle fault is sorted mechanically. OBD1 will happily let you chase ghosts all weekend, ask me how I know.
  23. 99z34na
  24. Black92GS
  25. 99z34na
  26. 55trucker
  27. 99z34na
