  2. Today
  3. SuperBuick
  4. Yesterday
  5. 94 olds vert
    My Turbo 99 Z34 Monte Carlo
    Wow that car is awesome!
  6. White93z34
  7. Last week
  8. Schurkey
  9. SuperBuick
  10. SuperBuick
  11. babyteef
  12. Ch3vyDude
  13. Ch3vyDude
    Wow this thing is beautiful!!
  14. Psych0matt
    TRW Keyless Entry module
  15. GnatGoSplat
  16. babyteef
  17. mdpierce8
  18. Earlier
  19. GnatGoSplat
  20. White93z34
  21. mdpierce8
  22. GnatGoSplat
  23. JulienStocola
  24. Bake82
  25. 55trucker
  26. Black92GS
  27. so this is my first post here on this forum and i don't quite know what to get out of it, as you saw I'm attempting to get all pieces together to get a 5.3L LS4 with the transmission, all wiring ecu tcm is all connected, the entire subframe setup was taken down from a impala to swap into my 95 Oldsmobile Cutlass Supreme SL. Being a obd 1 car i don't know if its only the ecm/ecu that runs the tranny or if there's a bcm ( body control module) that goes with it, that being said this car was given to me as a gift from my grandfather who recently passed, so if you guys are tryna convince me to start with something else forget it, ive seen the motor go into the car already and the guy who posted it here was even brave enough to get a 4t80 inside along with it. my main question is what ecu and standalone kit would be best used for this setup as i only see all other ecu's being compatible with the other LS engines instead of this one
  28. GnatGoSplat
  29. Yep, I've probably removed the bezel a hundred times across 3 Cutlass Supremes and it's never broken. It's hard plastic and seems brittle, but it's actually quite durable.
  30. Good point, it may. I'll keep an eye on it. My feeling is at this point it will outlast that car. It will be interesting to see and I'll check in after a while to let the members know. Thanks for the feedback
