wwindyibis joined the community -
fern_anchor joined the community -
nanowl72 joined the community -
89 olds swaybar
willowhammer2 joined the community -
pinekettle joined the community -
leafyrook67 joined the community - Earlier
brightbuck95 joined the community -
Red Menace joined the community -
do you know were i can found the timing belt tensioner for this car the motor is 3.4 lq1 am changing the timing belt but mine is crying oil i need a new on the part number is GM 24503860 -
would any one know how to get a 3 port vacuum harness? ive got a 93 Buick regal with a 3.1 multiport Fi and i need a 3 port. i cant find any parts diagrams anywhere with a 3 port, and no junkyard within 30 miles of me even has an old 3100 engine that i can look at. ive found plenty of 3700 and 3800 of different makes and models, but none even have a 4 port harness. mine was badly rotted from never being touched for 30 years and ive lost powered brakes, my ac selector no longer works and my power steering locks up whenever i give it around half or more than a half press of my brake peddle, causing me to almost crash every time i have to make a turn without stopping fully. im going mad trying to search for it, every idiot behind a parts counter at every auto parts shop have no clue what im talking about and i can not for the life of me find a part number for a 3 port, i cant find any diagrams with a 3 port, and no one sells anything but a "do it yourself kit" with hose barbs and universal hose i have to cut to length -
