mdpierce8 reacted to a post in a topic: TRW Keyless Entry module
rich_e777 reacted to a post in a topic: DOES ANYONE KNOW WHERE TO GET LATERAL LINKS FOR 95 CUTTY???
That's a daunting swap! Wish I had the balls to do it, but I draw the line at cutting away at a unibody frame that likely wouldn't have won any 1995 IIHS safety awards in the first place. You're all good BCM-wise, there isn't one. - Last week
JulienStocola reacted to a post in a topic: 5.3L LS4 swap into a 95 Oldsmobile Cutlass Supreme SL
GnatGoSplat started following Radio replacement for a 1994 Cutlass Supreme Convertible and 1993 Cutlass convertible top not moving, down or up
Yep, I've probably removed the bezel a hundred times across 3 Cutlass Supremes and it's never broken. It's hard plastic and seems brittle, but it's actually quite durable. -
Cojack87 joined the community
Jakey joined the community
