  2. Yesterday
  3. Mach 5
    awesome!
  4. Last week
  5. Bake82
  6. rich_e777
  7. SuperBuick
  8. 94 olds vert
    My Turbo 99 Z34 Monte Carlo
    Wow that car is awesome!
  9. White93z34
  10. Earlier
  11. Schurkey
  12. SuperBuick
  13. SuperBuick
  14. babyteef
  15. Ch3vyDude
  16. Ch3vyDude
    Wow this thing is beautiful!!
  17. Psych0matt
    TRW Keyless Entry module
  18. GnatGoSplat
  19. babyteef
  20. mdpierce8
  21. GnatGoSplat
  22. White93z34
  23. mdpierce8
  24. GnatGoSplat
  25. JulienStocola
  26. Bake82
  27. 55trucker
  28. Black92GS
  29. so this is my first post here on this forum and i don't quite know what to get out of it, as you saw I'm attempting to get all pieces together to get a 5.3L LS4 with the transmission, all wiring ecu tcm is all connected, the entire subframe setup was taken down from a impala to swap into my 95 Oldsmobile Cutlass Supreme SL. Being a obd 1 car i don't know if its only the ecm/ecu that runs the tranny or if there's a bcm ( body control module) that goes with it, that being said this car was given to me as a gift from my grandfather who recently passed, so if you guys are tryna convince me to start with something else forget it, ive seen the motor go into the car already and the guy who posted it here was even brave enough to get a 4t80 inside along with it. my main question is what ecu and standalone kit would be best used for this setup as i only see all other ecu's being compatible with the other LS engines instead of this one
